586,103 active members*
3,304 visitors online*
Results 1 to 7 of 7
    Feb 2012
    87
    Questions about DSP controller
    Hello friends, tell them I have a cnc router with DSP control and has emerged me a doubt and is steps from the XYZ axes, the least I could do go manually (by pressing the buttons on the DSP) is 0.1mm, and sometimes I can not center well because 0.1mm is much forward motion for centering small letters, maybe if 0.05mm would be excellent, but not as you can configure, does anyone know about this?
    Thank you very much and if you do not understand my question I make a video, let me know
    Jan 2006
    509
    Re: Questions about DSP controller
    You should be able to change the distance of the steps in settings
    Shannon.
    Feb 2012
    87
    I thank you for your answer, the problem I do not know how to do you can tell me how to be configured?
    Jan 2006
    509
    If you push the menu button there should be a list that comes up, can you find anything that is similar to "step units"? Depending on the menu file installed you might not be able to change it?
    Do you have the handset host program installed on your computer?
    Shannon
    Feb 2012
    87
    You can see this video? steps are set to 0.5mm and 0.1mm,
    https://youtu.be/IYATalTP9Tk
    I would ask if you help me step by step, you can see the options in the video2
    https://youtu.be/kLM01e9jsgc
    Jan 2006
    509
    I made up my own menu files to access the ability to change the step setting.
    A workaround is to use the Dist (Distance) mode and set it to 0.05mm. Then you can move in smaller distances.
    Shannon
    Jan 2006
    509
    I just remembered how to change the step settings easily
    If you have it set to low step, then push the "STOP" button. Push the 'X-' button 3 times and you can change the step distance there. Push the 'RUN/PAUSE' button and then type in your setting and press the "ORIGN/OK" button to save the new settting.
  1. M32 controller questions..
    By tnik in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 07-10-2012, 10:00 PM
  2. controller box questions
    By maker of things in forum Benchtop Machines
    Last Post: 04-05-2012, 02:15 PM
  3. controller questions
    By scrambled in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 04-01-2011, 03:50 AM
  4. Motor and controller questions
    By sYmbot2 in forum Community Club House
    Last Post: 10-11-2008, 06:43 AM
  5. Stepper controller questions
    By petec in forum CNC Machine Related Electronics
    Last Post: 04-27-2004, 01:15 AM
