586,119 active members*
3,367 visitors online*
IndustryArena Forum > MetalWorking Machines > Tormach Personal CNC Mill > How to do I edit the post process in Fusion 360
Results 1 to 6 of 6
    Oct 2016
    i have a tormach 770 i just bought it has the path pilot . whenever i post with fusion 360 it spits out a M998 .This M998 seems to want to crash the spindle into the work piece . When i manually delete it the post is good . Is there a way for it to not spit this line of code out ?
    I have no tool changer on the machine. They all need to be changed by hand.
    Apr 2016
    109
    Re: How to do I edit the post process in Fusion 360
    You want it to move in Z axis only. There's no way to crash into the part if it only moves UP. Check a current manual Page 61 and 68. Here's the relevant bit from page 68:
    G30/M998 Move in Z Only – The G30 or M998 G-code commands can be used to move the mill to a pre-set position. The position is settable using the Set G30 button on the Offsets screen. A G30 or M998 command is typically programmed right before a tool change line in G-code programs so that the spindle head clears the workpiece with sufficient distance to be able to change tools. When selected, this option moves to the tool change position in Z only, otherwise a coordinated XYZ move occurs on G30 or M998.
    According to the manual, M998 and G30 behave identically on the Tormach.
    Sep 2009
    1856
    The 3 vids here show everything you need to know
    https://www.youtube.com/watch?v=a2iJ...EFpw-Px8dAxnEL
    and if you do a search here there are a few tormach posts Inventor HSM & HSMWorks CAM - Autodesk Community
    http://danielscnc.webs.com/
    being disabled is not a hindrance it gives you attitude
    [SIGPIC][/SIGPIC]
    Looking at the tormach.cps, there is only one place where the M998 is added.
    Do a search for "writeBlock(mFormat.format(998));" and either delete it or put "//" in front of it to comment it out.
    I haven't watched the attached videos, but I'm sure they mention that after editing you should move the post file out of the webdeploy/production/xxxx/Applications/CAM360/Data/Posts directory or you can lose your edits with the next update.
    Dave
    Feb 2006
    7063
    Modified posts should be placed in: C:\Users\YourUserName\AppData\Roaming\Autodesk\Fus ion 360 CAM\Posts
    Regards,
    Ray L.
    Quote Originally Posted by SCzEngrgGroup View Post
    Regards,
    Ray L.
    Yeah, guess I should have mentioned that. And the caveat - Unless you're one of those MAC people...
