586,119 active members*
3,472 visitors online*
IndustryArena Forum > Mechanical Engineering > Mechanical Calculations/Engineering Design > Newtonian Pressure Drop vs Non-Newtonian Prssure Drop
    Oct 2016
    Question Newtonian Pressure Drop vs Non-Newtonian Prssure Drop
    I did some experiments on Newtonian and non-Newtonian fluids measuring the pressure drop through a horizontal pipeline. The Newtonian two-phase flow was water+air and the non-Newtonian was (water+xanthan gum)+air.
    I prepared 2 samples (2 concentrations) of the xanthan gum solution 1g/1L (995 kg/m3) and 2g/1L (990 kg/m3). I am wondering if it is logical that the Newtonian pressure drop was bigger than the non-Newtonian one?! Also the 2g/1L sample should've been with a higher density comparing to the 1g/1L!
    Mar 2006
    202
    Re: Newtonian Pressure Drop vs Non-Newtonian Prssure Drop
    How does the viscosity of the water+xanthan gum+air change with shear? Some non-Newtonian fluids, like blood, get thinner with shear. Others, like corn starch in water, get thicker.
    The flow rate will affect it also. Higher flow rate means higher shear. I suppose too you need to know if the mixture changes the friction against the tube wall.
    Oct 2016
    Quote Originally Posted by vegipete View Post
    The xanthan gum solution gets less viscous as the shear stress increases so, when we increase the flow rates, the shear stress increases and it will result in a small pressure drop.
  1. Micro drop
    By riche543 in forum Mechanical Calculations/Engineering Design
    Last Post: 02-23-2012, 06:44 PM
  2. Measuring the pressure drop down a pipeline
    By martinw in forum Mechanical Calculations/Engineering Design
    Last Post: 12-24-2008, 05:01 AM
  3. I don't have an art drop down menu
    By Raion in forum Mastercam
    Last Post: 09-12-2008, 12:25 AM
  4. Xpress to drop ads?
    By moyesboy2 in forum Uncategorised CAD Discussion
    Last Post: 11-02-2005, 03:21 AM
