I remember having the entering 400 long back when I did mine, it is tricky getting the far left digits entered especially if there is a max number (hard-coded in the firmware that it won't let you go over) another thing verify your spindle has 220 volts on it. if your power in is 220.
try going left of the 50 and put 3 and then change the 5 to 0 and then back to the 3 and change to 4
Try it in the order that that was posted here before
you already did the factory reset so go to step 2 and hang d002 first then d001 and so on.
1) Reset the VFD to factory settings
a) Set D001 to 1
b) Set D176 to 1 and press Func (this resets VFD to factory settings)
c) Set D001 to 1this allows you to change settings
2) Reset the VFD to 400Hz max operating frequency rather than the 50Hz default:
a) Set D002 to 400 (need to set this before D000)
b) Set D000 to 400
c) Set D003 to 400
d) Set D009 to 400
e) Set D021 to 400
f) Set D093 to 400
Yes this set mine. Thanks now to find how to set everything else
We use cookies to optimize our website for you and to be able to improve it continuously. By clicking the "Accept" button, you expressly agree to the use of cookies. For further information on cookies, please refer to our privacy policy.
