Hello.
I have an OKK MCV 630 that has had a Camsoft retrofit put on it (by the previous owner)
I cannot figure out how to get cutter comp to work (G41 and G42).
I have tried calling up the tool # in the line prior to the comp line and it does nothing.
I have tried putting the tool # in the comp line and it does nothing.
I am using tool #1 and that is where I have the comp value loaded as well (on the tool screen in Camsoft). So my tool length and comp value are in the same address (T01)
Does Camsoft require the tool length compensation and cutter comp value to be entered as 2 seperate adresses, T01 for tool length and T41 for comp value as an example?
