586,068 active members*
3,739 visitors online*
    Oct 2007
    13
    Omio X8-2200L vs Jinan LXG0609 ?
    Does someone know how the Omio X8-2200L would compare to the LXG0609 ?
    From the specification, something abvious is that the Omio is made from aluminium (weight about 80kg) when the jinan is made of steel (200kg). Given positionning accuracy is a bit different, but probably can't be trusted anyway The spindle seems to be able to turn slower on the jinan (great for drilling holes). I don't know how the "Hiwin Rail Linear Bearings and Ball Screw" would compete to the "HG20 Linear Guideway".
    On the link I provided, the spindles is 1.5kW for the jinan vs 2.2kW for the omio, but 2.2kW and 3kW are available.
    Thank you,
    fabien.
    Dec 2012
    390
    Re: Omio X8-2200L vs Jinan LXG0609 ?
    It looks like only Y-axis use Hiwin rails, while the other two axes use regular linear bearings, which is not as good as HG20 linear rails.
    Oct 2007
    13
    The model I linked seems to have linear bearings, but they also have a $2700 model with same reference which (on the picture) has 2 rails on each axis, and (in the specs) has a 2.2kW motor :
    https://www.aliexpress.com/item/Gold...4-4c6cc30044e2
  1. New Omio Machines! Opinions?
    By Polymorphism in forum Chinese Machines
    Last Post: 08-15-2020, 07:59 AM
  2. omiocnc X6-2200L, bad PSU?
    By Dustmite in forum Chinese Machines
    Last Post: 04-06-2017, 02:15 AM
  3. Which one should I choose, omio x6 cnc or ox cnc kit?
    By rieu in forum Commercial CNC Wood Routers
    Last Post: 01-15-2016, 03:44 PM
  4. X6-2200L or... ?
    By Jmac80 in forum Chinese Machines
    Last Post: 10-27-2015, 04:46 PM
  5. Replies: 10
    Last Post: 03-02-2015, 07:33 PM
