586,525 active members*
3,113 visitors online*
IndustryArena Forum > Laser Engraving and Cutting Machines > Laser Engraving / Cutting Machine General Topics > Using LASER Engraving to remove plastic coating over steel
Results 1 to 3 of 3
    Mar 2006
    81
    Hey guys,
    As the title says, I'm having some issues using my 20W Fiber LASER Engraver to engrave a logo on plastic-coated steel (the item is a piece of eyewear- a colored eyeglasses arm).
    The settings I use either create a plastic bubble, or a burn zone around the material, or they do not penetrate and vaporize the plastic enough, leaving a thin 'raised plastic' zone.
    Engraving with harsher settings (more power, higher frequency, changes in pulse width) are somewhat more successful at removing the plastic, but then the material under them gets a black burn mark. This problem I can alleviate by doing a second engraving using a clean-up pass, resulting in a white finish, which is ALMOST what we want.
    To add insult to injury, there is an already-existing successful engraving on the piece which has no burn marks around and looks nice and white. Argh! xD
    Feb 2009
    6028
    Re: Using LASER Engraving to remove plastic coating over steel
    Fiber laser may be the wrong wavelength for plastic...
    Typically CO2 is used for plastics.
    Sent from my A3-A20FHD using Tapatalk
    Mar 2006
    81
    I got it to work!
    However, it takes more passes than normal to clear off the plastic.
    Follow that up with a nice Steel-friendly engraving for a White Finish. Looks great, but there are different settings one would have to apply based on what color coatings.
    The red coating was the one giving me the most issues. Black was easy, and so was yellow, and blue was alright.
  1. End Pumped Laser Marking Machine better for engraving plastic
    By consurelasercnc in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 05-06-2016, 05:04 AM
  2. need help with laser engraving plastic name plates
    By gmautz in forum Signmaking Topics
    Last Post: 04-28-2015, 06:11 PM
  3. Laser for engraving metal - the phosphate coating off of steel and annodized aluminum
    By Kcinnick in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 12-07-2013, 10:04 AM
  4. Laser engraving of steel and solid carbide
    By JERRIMY in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 02-21-2008, 07:03 PM
  5. Bronze coating carbo steel
    By skipperspride in forum Material Machining Solutions
    Last Post: 02-04-2008, 03:50 PM
