586,032 active members*
2,993 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Mach Software (ArtSoft software) > Need help with Mach3 modbus settings with Hitachi WJ200
    Hi
    My Hitachi X200 vfd just went up in smoke, been working great for years, was using Mach3 to control the VFD thru modbus. Just changed out the Hitachi drive to the new WJ200 series. Now I can not get the setup to work. Does anyone have the settings to use in Mach3 for WJ200? Plus I also need the brain file, and the parameters for setting up the WJ200 Hitachi drive
    Apr 2013
    1899
    Re: Need help with Mach3 modbus settings with Hitachi WJ200
    Quote Originally Posted by macplus View Post
    Hi
    ...but you had the X200 using Modbus. So what's the problem? Just open the manual of the WJ200, check relevant chapters, change the Modbus configuration in Mach3 by entering the new parameter addresses and edit/change the Brain file you already have for the X200 and adjust to your new VFD.
  1. Mach3 modbus settings with Hitachi WJ200 - so close yet so far
    By kbmyers in forum Mach Software (ArtSoft software)
    Last Post: 09-29-2016, 02:12 PM
  2. hitachi VFD WJ200-037LF and HSD ES915A2P Spindle settings
    By shnitzel in forum DIY CNC Router Table Machines
    Last Post: 06-22-2015, 10:36 PM
  3. Hitachi WJ200 Settings Help
    By BanduraMaker in forum Spindles / VFD
    Last Post: 10-09-2014, 05:25 PM
  4. Hitachi X200 VFD, RS485 MODBUS, and Mach3
    By MechanoMan in forum Spindles / VFD
    Last Post: 08-17-2014, 09:50 PM
  5. Mach3 with Hitachi VFD using Modbus
    By swinn in forum Mach Software (ArtSoft software)
    Last Post: 11-28-2008, 07:44 PM
