586,096 active members*
3,004 visitors online*
IndustryArena Forum > CAM Software > CamBam > Cambam Pre-amble and Post-amble
Results 1 to 7 of 7
    Apr 2010
    21
    Some CAM products allow a file/storage/window to allow entering and to retain Pre-amble and Post-amble Gcode that is combined with the Gcode file produced.
    Can Cambam do this ?
    John
    Nov 2012
    1267
    Re: Cambam Pre-amble and Post-amble
    You can insert your code into the "Header" and "Footer" fields in the post-processor settings, would that work?
    Apr 2010
    21
    Thanks for the clue.
    Launched a trial (free) version of Canbam, chased down the Post-processor and found the fields you describe.
    Thanks you very much.
    My local mens shed has an Arduino router and one of the guys uses Cambam.
    We are slowly getting on top of all aspects of the machine.
    My question was to assist in getting our jobs to include post-amble code to move the machine to a safe zone to allow safe change of jobs.
    John
    Nov 2012
    1267
    You are welcome. Keep in mind that you can define the {$clearance} macro instead of inserting straight g-code into the footer. That way you can redefine it later on a per part basis if necessary.
    Apr 2007
    663
    A real easy way is to just write in G0 X0 Y0 after the G0 Z height command at the beginning and end of the G-code program that come from CAMBAM.
    Nov 2012
    1267
    If you need to do it just for one part, sure, you can simply open the G-code file and insert the necessary commands. If you need it more than once, makes more sense to use macros.
    Apr 2007
    663
    Citizen is correct on both counts [one-time and many-times].
    Often by writing directly in the G-code file, a user gets a better sense of G-code and where to insert headers and footers.
    I finally got a firm grasp, to the extent possible!, by writing G-code files by hand. Though time consuming, it really made me think about what CAMBAM generated files were doing, as well as allowing me to proof the files before they ran. After writing by hand, I broke a lot less router bits.
    Every little bit helps.
  1. CamBam / Path Pilot Post processor
    By SomeWhatLost in forum Tormach PathPilot™
    Last Post: 01-04-2016, 05:37 PM
  2. CamBam Post for Path Pilot
    By phoneman in forum Tormach PathPilot™
    Last Post: 03-28-2015, 02:36 AM
  3. Reviving post. Biesse Rover 35L and CamBam
    By denmark219 in forum Commercial CNC Wood Routers
    Last Post: 01-06-2015, 06:08 PM
  4. CAMBAM post processor q.
    By PeterF in forum CamBam
    Last Post: 03-26-2010, 07:44 PM
