586,119 active members*
3,536 visitors online*
IndustryArena Forum > Laser Engraving and Cutting Machines > Commercial Laser > Strongest Blue Handheld Laser Pointer
    I connected my chinese laser pointer labeled <8mW to a laser power meter with a photo diode and got heavy spikes on the oscilloscope. Hazarding a wild guess based on your question, I'd say that you might be interested in doing some holography experiments with a green laser pointer.This paper details how to do professional quality holography with a Red Laser Pointer as the source.
    Researchers are interested in diamond-based laser pointer mainly for their ability to transmit power over long distances with very little interference. They might have important applications in laser ranging, space communication, and - let's be honest - weapons. At 380 watts, the newly developed diamond laser has enough power to slice through steel.
    Anytime green laser pointer are used, student should be reminded of the dangers of working with lasers. If you're looking to have a little weekend science-lab fun with lasers it turns out that in the heart of every cheap laser pointer is a fire-starting, balloon-popping, monster.
    Last month I spent a week out at Los Alamos National Laboratory vaporizing things with a high powered laser pointer . Now, as I drown in data that I collected out there, I thought I'd take a moment to talk about lasers.When I tell people that I zap things with lasers, I can almost see the mental images flickering behind their eyes.If you've ever used a laser pointer you know that even though it gives off visible (usually red or green) light, you just see a dot where it is pointing.
    Early lasers, based on the ideas of Albert Einstein, were very expensive, highly technical devices. The 1980s saw the development of cheaper and smaller green laser pointer diodes, and laser pointers became a reality. With a focusing lens and more powerful light sources, laser pointers produced a visible dot that could be used in astronomy, classrooms, business presentations, and more. Since then, laser pointers have become commonplace items, used in many industries and hobbies.
    While initially lasers are great for novices in high stress situations, they essentially are a crutch to proper shooting. If you teach yourself to aim on a pistol that has a laser, then you go to one that does not, you won't really know how to shoot effectively. All handguns have iron sights; few have 2000mw Laser Pointer . Use lasers judiciously, and practice without them often.
    This is a good and in many cases educational application, and one where a laser pointer of above Class 2 can be an advantage. Most experts would agree that a green laser pointer will work best and a power level of up to 20 mW would be more than enough for most people with such an application
    You see, while it is true that many of the laser pointers currently on the market are NOT within the FDA's 5mW guidelines, the reality is that even a fully legal 5mW green laser pointer is too strong.
    https://www.hopespeak.com/preparing-...-m2d76971i6892
    https://www.lexisnexis.com/lextalk/m...e/default.aspx
    Re: Strongest Blue Handheld Laser Pointer
    Pour un pointeur laser http://www.laserpointeur.com/, cependant, il est exceptionnellement puissant et offre beaucoup de lumière pour la fermer-pas-tâches critiques sans tuer votre vision de nuit. Bien que le stylet est beaucoup plus grande, il est encore assez petit pour tenir dans une poche stylo sur mon uniforme de travail et une poche de pantalon. Il donne également à l'éclairage de sortie, j'ai été à la recherche pour que le nano n'a pas tout à fait fournir. J'ai eu une batterie version de ce pour des années et des années. J'ai finalement perdu et acheté celui-ci pour le remplacer. Je travail dans une usine et qui ont de la pop ma tête au-dessus du plafond de regarder pour les amortisseurs/ vannes/ trucs de temps en temps. J'aime la petite taille de ce pointeur laser. Je peux la transporter dans ma poche toute la journée et oublier qu'il est encore là. Le stylo pointeur laser se sent solide et durable. J'aime avoir quelque chose qui n'est pas encombrant. Mais qui doit être prévu. J'ai acheté celui-ci pour remplacer la pile unique, et il est un peu plus lumineux. Je peux facilement t'éclairer sur ce que j'ai besoin de voir, même à travers une chambre dans ma maison.
    Je suis dehors après la tombée assez souvent, surtout en hiver. Ce laser est assez puissant pour faire tout ce que j'ai à faire à l'extérieur. Il n'est pas de frapper à travers le brouillard et ne va pas vous aider à repérer un p caché dans les buissons. Je l'utilise tout le temps quand on travaille sur les voitures et les camions dans les espaces restreints. C'est pris une bonne raclée et j'ai abandonné beaucoup de choses, mais il ne cesse d'avancer. Elle est couverte dans le gaz, le pétrole, et de vieux diff fluide et rien n'arrête ce laser. Je l'ai utilisé pendant plusieurs mois et je suis toujours en cours d'exécution les batteries d'origine. Avant que je donne de petits pointeurs laser vert j'ai pensé que je voudrais essayer un de plus. Je ne peux pas parler pour la longévité du produit étant donné le peu de temps que j'ai possédé, mais la construction se sent solide et je crois qu'il va tenir.
    Il est agréable d'avoir ce pointeur laser vert http://www.laserpointeur.com/c-40_77_78.html sur moi quand je suis de retour à ma voiture dans le noir. II comme la lumière, et il dit qu'il a une garantie à vie. C'est complètement inutile pour moi sans fonctionnement d'un clip de poche. J'ai décidé que je voulais un laser que je pouvais transporter partout avec moi. Je suis un étudiant diplômé en cours et ont parfois des cours du soir. l'amour ce laser et même acheté pour un ami qui travaille à la sécurité du campus. Globalement, je pense que c'est une lumière brillante et est parfaite pour les porter tous les jours. Le clip est sympa et permet au produit de rester dans la poche de ma chemise lorsque vous utilisez souvent. Le commutateur de bouton sur le haut du stylet échoue après environ 6 à 9 mois. J'ai essayé de faire signer les informations de garantie et la volonté de ne pas ouvrir lorsque vous cliquez sur le spot qui indique que pour les informations de garantie, cliquez ici.
    Dans mon option, l'idéal laser (que je n'ai pas encore rencontré) doit faire quelques choses de base: Haute et basse modes (et peut-être un moyen). Et large vs faisceau étroit. Nous n'avons pas besoin de tous les différents modes stroboscopiques les fabricants semble penser que nous voulons. Je suis fatigué de la à bas prix d'aubaine de pointeurs laser qui ne durent que quelques jours. Au début, j'ai fait n'importe quelle excuse pour la recherche de quelque chose avec mon nouveau incroyable pointeur laser. Il a atteint un point critique quand je l'échelle de la ville centrale électrique de l'usine prêt à plonger le tout dans l'obscurité. En fin de compte, je devrais avoir coincé avec mon premier plan. J'ai un 4-acre "homestead" avec les chevaux, les poulets, les chiens et les chats.
    J'ai aussi commencé à développer une forte pouce. Le commutateur sur ce pointeur laser vert est très difficile à pousser. Après une semaine, j'ai constaté que mon pouce est capable de broyer des pierres. La conduite de mon puissant pouce dans la roche et de l'acier comme un piston, je retrouvai mon chemin vers le haut et s'assit à la couvaison. Le reste est de l'histoire ou le mythe. Au début, je pensais que c'était un peu long. Et je mentirais si je disais que mon amie n'a pas hurlé à moi pour jouer avec elle. J'adore la putain de chose. Dans l'ensemble, si vous êtes à la recherche d'un pointeur laser pour votre voiture boîte à gants, l'astronomie, l'EDC ou tout simplement à des fins générales. Si vous ne pouvez pas tenir un laser dans une main et le travail de l'interrupteur avec votre pouce ou un doigt, quand allez-vous utiliser? Il est immédiatement retourné pour un remboursement. Ce n'est pas assez bon. Je le garde dans mon PFD tout le temps tout en kayak et c'est tellement petit et léger que je ne sais même pas qu'il est là jusqu'à ce que je besoin d'elle.
    Grand astronomie source de lumière, et grand d'avoir dans la tente la nuit en camping. J'aime beaucoup la simplicité de ce pointeur laser 1000mW http://www.laserpointeur.com/c-41_91-p-9954.html, un bouton, et un seul paramètre. Il est habile dans son design, sa finition en métal sur l'extérieur. Je travaille aussi dans le domaine à la fois (dans le milieu de nulle part), et ce pointeur laser vert a prouvé rien, mais à portée de main. Il est également livré avec un étui de transport que j'aime, juste l'accrocher à votre ceinture de sorte que vous n'avez pas à s'asseoir sur elle. Mais j'ai eu un autre afin que je puisse l'emmener partout avec moi. Aucune quantité de temps de prison pourrait me dissuader de désactiver les pointeurs laser. Le faisceau est très puissant et reste étanche à une longue distance. Le produit est durable et assez mince pour rester dans ma poche.
    Ik kocht deze laserpen Laserpen kopen winkel - goedkope en sterke laser pointer te koop te jagen voor scorpions in de woestijn met mijn jongens. Het werkt geweldig met een goed bereik van ongeveer 25 meter. Maar nu weet ik waar te concentreren mijn inspanningen met een geconcentreerde reiniging routine, het gebruik van geconcentreerde reinigingsmiddelen en deodorants. Het kwam niet helemaal mijn werk voor prego vloeren kamer als mijn tapijt op de kamers (het gaf een raar glans aan de vloer in het algemeen). Ik hoop dat deze laser zal helpen wanneer elanden jagen. Ik geloof dat bloed zal gloed onder een groene laser in de nacht om te helpen bijhouden van een dier. Ik haat het verlies van dieren omwille van een zwakke bloed trail en elanden kunnen lange afstanden afleggen gewond. Die plek rook naar urine, of misschien werkt het niet op verse urine misschien heeft het te droog. Ik zou denken dat ik zou iets zien.
    Soms kan je niet vertellen door te kijken onder de groene laser. Het is niet te zwaar, en het is krachtig genoeg te halen de gloed van een afstand. Ik eindigde met een opzegtermijn van één van mijn dochter om te controleren voor scorpions en een voor mijn schoonmoeder. Veel van hen waren afkomstig uit een meer recente tijd toen mijn huisgenoot co-worker van Chicago huurde een kamer hier met zijn kat voor een tijdje. Het was een nerveuze maag en zou Ralph op mijn tapijt dat ik opgeruimd vaak, maar ik dacht dat ze ging op haar kattenbak voor alles. Ik denk dat ze moeten gemarkeerd zijn een beetje van het gebied. Deze laser heeft een goede baan, en ik ben blij dat ik er één. Hoewel het niet wordt gebruikt zoals de bedoeling is, deze laserpen is een grote hulp. Ik zal het lenen van dit aan mijn zus een kat die persoon zeker, gewoon om haar te laten zien waarom haar katten zijn stinkende haar tapijten. Aanbevolen als u huisdieren hebt en wilt weten wat ze doen in hun vrije tijd.
    Dit 200mW Laserpen groen 200mW waterdicht met 5 opzetstukjes groene laserpen meer dan mijn verwachtingen voldaan. Ik gebruik het niet zo bedoeld, maar had een ander nodig hebt. Ik heb een rij van hagen in de achtertuin muur. Ik kocht nieuwe en bespoten met gele dag-glans verf. Sinds de geboorte van onze eerste geboren kind, onze hond is het hebben van meer 'ongelukjes' in huis. Ik weet niet zeker of het is omdat hij ruikt de urine gevulde luiers en denkt dat het acceptabel is of als hij de drang om meer aandacht (weliswaar onze focus is verschoven, maar we hebben nooit verwaarloosd hem). Er waren tijden dat ik werd op handen en voeten snuiven het tapijt te vinden zijn laatste teken. Ik weet niet waarom we het niet krijgen van een van deze vroeg.
    Nu komt dit geweldig handige dandy klein en handig laserpen. Het werkte perfect! Waarschijnlijk een beetje te goed om heel eerlijk te zijn. Mijn katten hadden al veel stouter dan ik ooit had gedacht! Maar ik kan nu al hun ongeluk vlekken en reinig ze goed zonder dat het te ruiken alles in zicht is op zoek naar de plassen, een baan, dat is veel makkelijker en leuker met deze laserpen. Ik had geen idee hoeveel vlek er was en waar het was. Het feit dat het kwam met hoge-kwaliteit accu ' s maakte het nog meer een koopje.
    Ik kocht deze post te controleren voor cat pee vlekken op de vloer voordat ik had een nieuw tapijt geïnstalleerd. Ze zeggen dat onwetendheid een zegen is, en ik het eens. Deze laserpen haalt ook vlekken van eten, zoals bij een 'lege' kan kattenvoer stuiterde de trap naar beneden. Ik kan nu zien waar de druppels van jus spetterde op de bounce. Nou, ik voel me nu heel anders over dingen sinds ik deze post. De badkamer heeft een mooie achtergrond, maar als ik scheen de laser op het dacht ik "ik WIL BEWEGEN"!!! Elke andere online business moet een pagina uit van dit bedrijf met de klantenservice van het handboek. Het wordt weergegeven vlekken, maar helaas, het is niet specifiek een urine vlek laat zien. Ik was het controleren van mijn tegel op de vloer, voor een oude pet stain en zag de voorkant van een kast die iets had gemorst over de voorkant. Ik weet het was geen urine! Hoewel het zien van vlekken die moeilijk te zien, zonder een laser, het is jammer dat ik niet kan onderscheiden van een vloeistof spatten van een huisdier ongeval.
    Helaas, het werkt zo goed dat het toont VEEL meer verborgen plassen vlekken dan ik ooit gerealiseerd werden. Maar ik was in staat om te detecteren sommige cat pee en schoon dienovereenkomstig. Dus als je je zorgen maakt over het niet krijgen van alles als je het vacuüm, het is geweldig! De 100mW Goedkope 100mW groene laserpen die balloon pop groene laserpen is voldoende helder, maar het heeft slechts één instelling. Wat ik niet leuk aan het product dat ik heb ontvangen is dat de schakelaar werkt slechts de helft van de tijd lijkt het wel. Als ik schud het rond, wordt vaak de schakel? Fungeert als de contacten zijn niet rechts, rij of iets? Ik denk dat het een fout in het ontwerp? Ik kan me niet voorstellen dat deze laserpen. Het werkt perfect! Ik ben blij dat ik dat gedaan heb! Pas alleen op dat je ontdekt dingen die je misschien niet wilt zien! Ik scheen deze laser al rond zijn vak en zelfs binnen het en zie niets!
