586,076 active members*
3,848 visitors online*
IndustryArena Forum > OpenSource CNC Design Center > OpenSource Software > F-Engrave help...clean up pass is not cutting in correct spot
Results 1 to 9 of 9
    Oct 2007
    446
    Question F-Engrave help...clean up pass is not cutting in correct spot
    I just started my first try with fengrave(v1.55)...i am doing a cleanup pass after my intial vcarve and for some reason is does not line up properly with the first v cut pass
    it looks almost like it needs to offset more by the amount radius of the bit...
    i overlaid the cleanup pass in magenta on top of the vcarve for reference to see what i mean. It needs to move over in x and y, you can see that the gap on the bottom and left side is not correct. And also the angled magenta lines did not retract when it traveled those so it cut through all of that.
    I cut my first vcarve pass, loaded the clean up pass leaving my x and y origin untouched and simply rezeroed for the new tool.
    has anyone else experienced this?
    Dec 2010
    226
    Re: F-Engrave help...clean up pass is not cutting in correct spot
    That looks really bad. Can you please send the g-code to the e-mail address in the F-Engrave Help Menu so I can take a look at it?
    If this is a repeatable problem it would help a lot if you could generate similar g-code and save it with the "Suppress Comments" option unselected in the F-Engrave "General Settings" window. This will save all of the settings in F-Engrave as comments in the g-code file.
    It would also be benificial for you to download the latest version of F-Engrave. F-Engrave Download
    Scorch
    www.scorchworks.com
    Oct 2007
    446
    thanks for the quick reply...i just noticed there was newer version and will give that a try also..not sure if its a version issue?
    will email you the code
    thanks
    Oct 2007
    446
    Just downloaded new version and tried it and it looks fine now...so maybe just an issue with 1.55 then?
    I will do a test piece with the new code and see...but it looks like it should be good.
    thanks
    Mar 2012
    192
    Is there a way to get fonts with single pass, and also with an image? If I remember correctly, if I import a bmp of a circle O, F-engrave will trace both the outer and inner diameter. Thanks.
    For example, I also just noticed that it appears the cutter here is not lifting between two separate objects (but that might be my free J-viewer software). I have drawn two squares, one solid black and another as an outline.
    Code:
    ( Code generated by f-engrave-1.58.py )
    ( by Scorch - 2016 )
    (Settings used in f-engrave when this file was created)
    (fengrave_set show_axis   1 )
    (fengrave_set show_box    1 )
    (fengrave_set show_thick  1 )
    (fengrave_set flip        0 )
    (fengrave_set mirror      0 )
    (fengrave_set outer       1 )
    (fengrave_set upper       1 )
    (fengrave_set v_flop      1 )
    (fengrave_set v_pplot     1 )
    (fengrave_set inlay       0 )
    (fengrave_set bmp_long    1 )
    (fengrave_set var_dis     1 )
    (fengrave_set ext_char    0 )
    (fengrave_set useIMGsize  0 )
    (fengrave_set no_comments 0 )
    (fengrave_set arc_fit    none )
    (fengrave_set YSCALE     .95 )
    (fengrave_set XSCALE     100 )
    (fengrave_set LSPACE     1.1 )
    (fengrave_set CSPACE     25 )
    (fengrave_set WSPACE     100 )
    (fengrave_set TANGLE     0.0 )
    (fengrave_set TRADIUS    0.0 )
    (fengrave_set ZSAFE      0.25 )
    (fengrave_set ZCUT       -0.005 )
    (fengrave_set STHICK     0.1 )
    (fengrave_set origin     Default )
    (fengrave_set justify    Left )
    (fengrave_set units      in )
    (fengrave_set xorigin    0.0 )
    (fengrave_set yorigin    0.0 )
    (fengrave_set segarc     5.0 )
    (fengrave_set accuracy   0.001 )
    (fengrave_set FEED       5.0 )
    (fengrave_set PLUNGE     2 )
    (fengrave_set fontfile   "LiberationMono-Bold.ttf" )
    (fengrave_set H_CALC     max_use )
    (fengrave_set plotbox    no_box )
    (fengrave_set boxgap     0 )
    (fengrave_set cut_type    engrave )
    (fengrave_set bit_shape   FLAT )
    (fengrave_set v_bit_angle 30 )
    (fengrave_set v_bit_dia   .1875 )
    (fengrave_set v_drv_crner 135 )
    (fengrave_set v_stp_crner 200 )
    (fengrave_set v_step_len  0.01 )
    (fengrave_set allowance   0.0 )
    (fengrave_set v_max_cut   -.02 )
    (fengrave_set v_rough_stk .005 )
    (fengrave_set v_depth_lim  -.105 )
    (fengrave_set v_check_all all )
    (fengrave_set bmp_turnp   black )
    (fengrave_set bmp_turds   2 )
    (fengrave_set bmp_alpha   1 )
    (fengrave_set bmp_optto   0.2 )
    (fengrave_set fontdir    "fonts" )
    (fengrave_set gpre        G17 G64 P0.001 M3 S3000  )
    (fengrave_set gpost       M5|M2  )
    (fengrave_set imagefile   "C:/temp/Untitled-1.bmp" )
    (fengrave_set input_type  image )
    (fengrave_set clean_dia   .1875 )
    (fengrave_set clean_step  90 )
    (fengrave_set clean_v     0.05 )
    (fengrave_set clean_paths  1,0,1,0,1,0 )
    (fengrave_set TCODE    070  045  069  110  103  114  097  118  101  010  010 )
    (fengrave_set NGC_DIR  "Y:\//" )
    ( Fontfile: LiberationMono-Bold.ttf )
    G90
    G20
    F5.00
    G0 Z0.2500
    G0 X0.0000 Y0.4636
    G1 Z-0.0050 F2.00
    G1 X0.0000 Y0.4636F5.00
    G1 Y0.0773
    G1 X1.0818
    G1 Y0.8500
    G1 X0.0000
    G1 Y0.4636
    G0 Z0.2500
    G0 X1.0045 Y0.4636
    G1 Z-0.0050 F2.00
    G1 X1.0045F5.00
    G1 Y0.1545
    G1 X0.0773
    G1 Y0.7727
    G1 X1.0045
    G1 Y0.4636
    G0 Z0.2500
    G0 X2.0864 Y0.4250
    G1 Z-0.0050 F2.00
    G1 X2.0864 Y0.4250F5.00
    G1 Y0.0000
    G1 X3.2455
    G1 Y0.8500
    G1 X2.0864
    G1 Y0.4250
    G0 Z0.2500
    M5
    M2
    Dec 2010
    226
    Quote Originally Posted by airbrush View Post
    thanks
    I didn't really expect the version to make a difference... After your previous post I went back to look at V1.55 and indeed the cleanup operations are royally messed up. I have done a lot of work with the latest version V1.59 so I am confident the problems have been resolved.
    Scorch
    www.scorchworks.com
    Dec 2010
    226
    Quote Originally Posted by 1875 View Post
    Most fonts are outline fonts and If you bring in an image F-Engrave will trace the outline. The v-carving option works well with these types of inputs.
    There are some "stick fonts" that are defined as strokes rather than the outline of the characters. There are a couple of links ant the bottom of the f-engrave web page for these fonts. Stick fonts work well for engraving text.
    Hershey Fonts (CXF)
    CamBam Fonts (TTF)
    If you want to cut single lines of an image you need to find some way to convert the image to single lines and bring it in as a DXF file. Someone sent me a link to a program that would convert images to lines but I don't remember what it was called... I will dig around to see if I can find it.
    ...I also just noticed that it appears the cutter here is not lifting between two separate objects (but that might be my free J-viewer software). I have drawn two squares, one solid black and another as an outline.
    The g-code you posted does include lifting the the tool between cuts.
    Scorch
    www.scorchworks.com
    Mar 2012
    192
    Thanks. I understand how it works, and it's fabulous!. The fonts are great too.
    Dec 2010
    226
    Here is some information that was sent to me regarding an online tool to convert images to single line vector format (suitable for engraving). I have never tried it but Rod had good success with it.
    Free Online Raster to Vector Converter
    Quote Originally Posted by Rod C. via e-mail on 2/2/2016
    ...I ran across this tool. It does a great job of taking an image and finding the center line. The DXF output is also broken up pretty good for engraving in single strokes:
    Pick:
    Centerline
    Adjust smoothness
    Output to DXF
    Click Trace
    Save DXF
    Import DXF into F-Engrave
    I was able to upload an A and it was turned into 2 operations with only 1 Z lift.
    Scorch
    www.scorchworks.com
  1. profile clean up pass
    By dotmkr in forum MadCAM
    Last Post: 07-01-2015, 11:30 AM
  2. Replies: 0
    Last Post: 07-03-2014, 07:00 AM
  3. bmp picture won't engrave clean
    By SKAHN612 in forum Community Club House
    Last Post: 12-27-2013, 05:33 AM
  4. One clean up pass after threading…T32B
    By Captdave in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 09-09-2009, 03:55 PM
  5. Multi pass cutting
    By sykic in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 12-30-2007, 02:52 PM
