586,094 active members*
3,872 visitors online*
IndustryArena Forum > OpenSource CNC Design Center > Arduino > Building first CNC-Need help
Results 1 to 2 of 2
    Apr 2012
    Hi Everyone,
    I've been a member for several years,but never needed to post anything till now. I'm building a small table top cnc (working area of 6" X 8") as a prototype for a hopefully larger one next. Almost done,but I have one problem(I think it's just one) standing in the way of becoming operational. All three axis work(move) individually, but when I hook up all three, the third one doesn't move. It just sits there and hums. I tried swapping driver boards and motors around, but they all worked in different scenarios,and the problem was still there. I thought maybe it was a power issue so I upgraded from a 12 volt psu power supply, to a 36 volt 10A switching power supply supposedly made for a 3d printer. Same problem.Also tried adjusting the current on the driver boards. Don't know where to go from here.Below is a list of my setup.Any help would be greatly appreciated.Thanks.
    • X&Y axis- Nema 23 2 phase (3.0A/phase (23HS9430B) Overkill,I know. But I hope to use them on my next project
    • Z axis- Minebea 17pm-J702 salvaged from old printer/scanner ( Works O.K. with a small engraver mounted.)
    • Power Supply- S-360-36 36 volt 10 Amp Generic power supply off Ebay
    • Arduino Uno
    • Arduino CNC Shield 3V from Protoneer
    • DRV8825 Polulo drivers
    • GRBL Controller 3.6.1
    Jan 2017
    Re: Building first CNC-Need help
    The drivers can only handle 2A max. Try adjusting the driver voltages down even further.
  1. Building my own
    By magno_grail in forum Drilling- and Milling Machines
    Last Post: 12-08-2012, 10:44 AM
  2. hi there building a new one
    By marcoooo in forum Benchtop Machines
    Last Post: 11-26-2010, 12:03 PM
  3. Building my first CNC!
    By IWorkInPixels in forum DIY CNC Router Table Machines
    Last Post: 11-19-2010, 05:49 AM
  4. Building my CNC
    By Atomic_Sheep in forum Uncategorised MetalWorking Machines
    Last Post: 10-25-2010, 09:12 AM
  5. Should I consider building a cnc or just buy one?
    By johnt in forum Waterjet General Topics
    Last Post: 03-28-2005, 06:19 PM
