Re: Buy or Build...That Is The Question
Originally Posted by
cavemancarver
If David sees this post maybe he can comment on the table he built from wood. It looks pretty impressive and I have been wondering how it is performing. Is it as sturdy as you had hoped it would be?
The problem is those power supplies are $110.00 each and if I am going to spend that kind of money I might as well go with one of the 4 axis Gecko setups which have the power supplies built in. That might cost me a little more money but I will end up with good quality drives and also save a lot of time without having to build a box and wiring everything not to mention the likely troubleshooting I will need to do. Any suggestions here would be welcome.
Again...thanks to everyone out there for letting me tap into your experience and knowledge.
More to come.........
I am very pleased with the wooden stand, very sturdy. I can't budge it in the X direction and it moves less than half inch at the top of the rails in the Y direction if I have the gantry moving quickly and stop it while jogging. When I flattened the spoil board there was a lot back and forth on X then incremental indexing on Y and I don't recall seeing it move when I did that (cutting at 250 ipm). But like I said somewhere, maybe here, I'm a woodworker so it just made sense that I would build a wooden stand. I can weld but don't have the tools or setup for doing much with metal.
On the 4 axis Gecko driver my only reservation would be that if one axis goes out do you have to replace all 4 or is it modular and you can replace one only? Just curious because I don't know...
David
David
Romans 3:23
Etsy shop opened 12/1/17 - CurlyWoodShop
