586,119 active members*
3,473 visitors online*
IndustryArena Forum > Maintenance in General > Maintenance DIY Discussion > HSD ES919 Spindle bearing removal help..
Page 2 of 2 12
Results 21 to 22 of 22
  1. #21
    15362
    Re: HSD ES919 Spindle bearing removal help..
    Quote Originally Posted by Stepping3D View Post
    mactec54, That's true I missed that, you could use oil or another coolant though. I know with mine, there was no way regular tools would have worked the first time it was rebuilt. Years of being run hot in a wood shop production environment, had locked everything together to a crazy degree. In my case, even the heat and cool wouldn't work first time, as I tried every trick in the book. Eventually after heating and cooling a number of times over an hour or two; using wax each time to cool the joint, it came off. I have had to re-machine most of the spindle as a result to get it back in shape... In retrospect it wasn't worth the effort and I should have picked a better candidate for rebuilding!
    If you had to use heat then you let it cool in the air and add penetrating oil once it has cooled
    You really don't want to be heating anything though when you dealing with precision machined parts like these High speed spindles even though your one did look pretty rough to start with, some penetrating oils work if there is corrosion and fretting, normally without the heat, you use a bigger lever with the right wrench if they are stuck, I have used up to a 6 foot extension to get the leverage needed to get some undone
    Mactec54
  2. #22
    Jun 2015
    Hello everyone! I am currently also in the process of replacing the bearings of an HSD ES919 spindle from a Biesse Rover.
    @Stepping3D Could you please give me some advice on the tightening torque for the top and bottom nuts and which thread locking fluid you used.
    Did you balance the shaft after replacing the bearings?
    Thank you very much in advance!
    Kind regards, Norbert
Page 2 of 2 12
  1. mazak vtc41 spindle bearing removal
    By jblmfg in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 03-11-2020, 02:19 AM
  2. Okuma Howa VMC spindle bearing removal
    By aryoung19 in forum Okuma
    Last Post: 06-28-2017, 08:27 PM
  3. G0704 Spindle bearing removal
    By rubberducky125 in forum Benchtop Machines
    Last Post: 04-30-2015, 05:32 PM
  4. Spindle Bearing Removal
    By RustedOut in forum Charter Oak Automation Support Forum
    Last Post: 07-03-2011, 04:20 PM
  5. X2 spindle bearing removal
    By skmetal7 in forum Benchtop Machines
    Last Post: 04-14-2007, 07:25 PM
