Originally Posted by
dustpan3
Also the screen shot did not show the safety block but if you see the top of the post ii do have G50 S6000
That is not safety codes..... that is only a speed limiter..... It should be a list of what codes are the default ( upon turning ON the machine ) to avoid problems if you had changed code for a special tool.
Code:
( HEADER COMMENTS Etc. )
G0 G40 G80 G90 G95
G50 S3000 M5 M9
G0 X444.
G0 Z888.
M01
On your screendump ... left of the seq. numbers
The upward pointing arrow is the line that is currently ready for execution,
- the greater than sign (>) is the what the control has read ahead to & placed into it's run buffer
Alarm seems to indicate that X & Z addresses may be required on a G32 line.....err ,,,, just looked up G32....you sure that is the code you want......this puts a scroll thread on the end face....not along the Z axis
You seem to realise that this code is just a single pass
try understanding & using the G72 cycle
PS
There is an Okuma machine forum.... lots of previous threads for you to read
