586,051 active members*
3,776 visitors online*
Results 1 to 10 of 10
    Nov 2014
    74
    Question 3d modelling help
    Hi guys/girls I was wondering if someone out there could help me out I have been struggling with making a 3d model of a poker chip tray with little success , I'm sure for someone with skills this would be a relatively simple task, If someone could help me out please give me a shout will give you the dimension's I'm looking for
    Thank I advance for al replies
    Steve
    Feb 2007
    4553
    Re: 3d modelling help
    Steve,
    Post a sketch and dimensions.
    Jeff...
    Patience and perseverance have a magical effect before which difficulties disappear and obstacles vanish.
    What format, or software?
    Nov 2014
    74
    I was hoping for a STL I will craft a drawing and dimensions and load it up here thanks for the reply
    - - - Updated - - -
    Thanks Jeff I will draw something up
    Quote Originally Posted by jalessi View Post
    Steve,
    Jeff...
    Nov 2014
    74
    the length is 8.8 inches the width is 4.5" the thickness is 1.5", dia of slots are 1.581" radius is.790 none of them go all the way through the bottom slots are so you can stack them, i did notice the width of the slots should be 3.5" not 3.25, can 4 models be drawn end to end with a .250 space between them?
    Thanks hope i didn't miss anything
    Here you go.
    Attached Files Attached Files
    Nov 2014
    74
    Here you go.
    Wow thanks I will check it out in the morning thanks again
    I apparently didn't look at the drawings properly, and only did one side.
    Also, you have two different sizes there. Is it 4.5, or 4.25?
    Try this one.
    Nov 2014
    74
    Thanks its perfect just checked it out I will post some pics when I cut them
    its 4.5 I could not delete the other drawings for some reason?
  1. Modelling A Pushchair
    By Raz11 in forum Solidworks
    Last Post: 01-23-2012, 06:41 PM
  2. Looking for a 3D Modelling Package
    By pbd1971 in forum Uncategorised CAD Discussion
    Last Post: 10-05-2011, 05:35 PM
  3. PRS modelling
    By betterfly in forum Musical Instrument Design and Construction
    Last Post: 08-13-2008, 10:00 PM
  4. Learning 3D modelling
    By randyf1965 in forum Uncategorised CAD Discussion
    Last Post: 01-12-2006, 01:27 PM
  5. Learning 3D modelling
    By randyf1965 in forum CNC Wood Router Project Log
