586,123 active members*
3,359 visitors online*
Results 1 to 12 of 12
    Aug 2006
    56
    Breakout board, Relays on board?
    Dear All,
    I need an opensource breakout board for my cnc. I appreciate Pminmo's breakout boards and i succesfully used 4 axis and 5 axis boards but now i need a board that have relays on board and screw terminals on it (instead of pin terminals) Is there any board around here or should i need to draw it again? If there is any eagle file around, i can modify and open its sources
    Thanks in advance
    Cooper
    Jun 2003
    3312
    I wouldn't recommend putting relays in that interface arena. Mechanical switching heavy loads is an emi nightmare. Kind of like putting a blindfold on and walking through busy streets, and hoping everybody will avoid you. Why would you do something that potentially will cause step insertion or loss issues and ruin a part. Put the relays away from open logic signals and wiring. Thats what the aux channels are for, to drive relays off the board. And preferably use a ZERO crossing SSR to switch ac signals.
    Phil, Still too many interests, too many projects, and not enough time!!!!!!!!
    Vist my websites - http://pminmo.com & http://millpcbs.com
    May 2005
    362
    It is not open source but I think they have a great board with relays on it. Try dtllc.com and look on the right side of the page for item # DB25RBOB
    Jun 2003
    3312
    If you have ever seen the EMI on a scope montoring logic lines when a mechanical relay switches, you would understand how big a no-no that is!
    Jun 2003
    3312
    Here is a link to make a discrete solid state relay:
    http://www.pminmo.com/wiki/index.php?title=Ssr
    Aug 2006
    56
    Dear Pminmo,
    Do you have screw terminalled version (instead of pin header version) of 4 axis interface? I need to connect seperate cables on step, dir, enable pins, so i need screw terminals. Is there any version of this board like this? If not and if you let, i can prepare and share it.
    Cooper
    Jun 2003
    3312
    Cooper,
    Why not just solder 22ga wires to the pads you need where the pin terminals would go? If you want a disconnect use simple automotive spade lugs in line.
    Aug 2006
    56
    Hehe, i'm a symmetry patient and i'm ready to draw pcb for screw terminals
    Btw, i saw miniature ssr on somewhere which is rated 250V 2A. Did you use that before pminmo?
    Cooper
    Aug 2006
    56
    Smile
    Dear All,
    I would like to thank you Phill, to draw screw terminalled version for me. Phill, you are the kindest guy, i've ever met in this forum. I'm very faithful right now.
    Thank you very much again.!:rainfro:
    Cooper
    Nov 2006
    6
    hi guys
    i ask for help , i have to design and fabricate a bob ( interface circuit between mach3 and 3-axes milling machine with linear encoders and DC sevo motors take more than 3A in start [ peak transient area of current may reach more 15A] ) it's first time to me to deal with mach or any software like this so i need help to do it soon , i have to prepare design in one week to send it to my professor
    thanks guys
    Jul 2006
    1062
    Quote Originally Posted by pminmo View Post
    Wow yours is the first "wiki" I've edited I can now make the SSR for my latest BOB equipped project :beer: now I just need to figure out how to make it switch a load As always it's great seeing the work you do :cheers:
    Keith
    Mar 2006
    15
    The DB25RBOB has relays on it and they will not interfere with your logic signals. The relays are turned on and off with devices that have protection from such EMI issues. I have sold many of these and have had 0 complaints. I also offer free tech help on my products if you need help e-mail or call me:
    David Delagrange, Owner
    Delagrange Technology LLC
    4024 Fairfield Avenue
    Fort Wayne, IN 46807
    Phone: (260) 557-9280
    Hours: Monday-Friday, 5:00 p.m.- 9:00 p.m.
    E-mail: [email protected]
    http://www.dtllc.com
  1. New Breakout Board.
    By arturod in forum News Announcements
    Last Post: 11-26-2006, 03:15 AM
  2. Breakout Board
    By bkkpool in forum CNC Machine Related Electronics
    Last Post: 07-28-2006, 07:15 PM
  3. Breakout board
    By joecnc2006 in forum CNC Machine Related Electronics
    Last Post: 06-29-2006, 03:33 PM
  4. What is a breakout board?
    By andy_ck87028 in forum Stepper Motors / Drives
    Last Post: 08-28-2005, 11:37 PM
  5. Breakout Board
    By ckirchen in forum News Announcements
    Last Post: 06-20-2005, 05:52 PM
