Wuhan Huagong Laser Engineering Co.,Ltd is a high-tech company which is always been at the leading edge of the R&D of laser technology and its application in China and has become the authoritative supplier for the holistic solution of laser processing."HGLaser" leading product covers complete power series including Laser Cutter Series, Laser Welder Series, Laser Marker Series, Laser Texturing Equipment, Laser Heat Treatment Series, Laser Tiny Process Series, Medical Operation Laser Equipment,solid& gas Laser Equipment, Laser Parts etc.
Fibre Laser Marker (LSF10)
Product Introduction:
The optical glass fibre laser marking machine has a homogeneous structure, any optical soiling, any power coupling losses and it has an air cooling system. In contrast to other laser machines, this laser machine has a high efficiency and reliability. Efficiency and a long duration of usage are the main arguments for customer’s choice and usage of this optical fibre laser marking machine.
(Pictures: Standard optical glass fibre laser marking machine, luxurious optical glass fibre laser marking machine
Essential features:
The laser beam has an excellent quality
Low running costs
This laser machine has a long duration of life
This laser machine has an exquisite volume and it is suitable for adverse circumstances
Application Fields:
-electronic components
-Electronically products
-IT industry
-automobile components
-metal tool production
-precision machines
-gifts and jewellery
-medical instruments
-electrical altimeter
Specification:
Type-number:
LSF 10 LSF20
Average Output energy:
10W 20W
Laser wavelength:
1064nm
Pulse repeated frequency:
20-80 KHz
Marking depth:
0.01-0.2mm
Smallest line width:
0.01mm
Energy supply:
100V-240V (single phase 50Hz)
Main engine size:
550x290x570 (mm) (standard)
Beams qualityM²:
1.4-1.8
Maximal straight line marking speed:
7000mm/s
Marking Surface:
Φ70 (standard), Φ100, Φ175 (optional)
Repeated precision:
0.2µm
Smallest type size:
0.2mm
Energy consumption:
<500W (excluding computer)
Cooling system:
air cooling
www.hglaser.com/english
[email protected]
tel:86 15994288030:rainfro:
