586,094 active members*
3,971 visitors online*
    Sep 2016
    Laser cutter power issue
    Hi everyone,
    I recently installed a new tube and power supply to my ls3020 laser cutter. Everything has been working fine for a few weeks (machine has done approx 30 hours of cutting/ engraving) however, I went to the machine today and have massively reduced power from the tube and it will not cut through 3 mm mdf.
    I ran a testjob and looked at the laser whilst it was cutting and I am getting a strongish purple glow from both ends of the tube but nothing in the middle. However, when I press the pulse laser button I managed to get a very strong full beam throughout the tube.
    Any ideas why I'm not getting the correct power when I'm trying to cut an actual job?
    Oct 2016
    14
    Re: Laser cutter power issue
    It sounds like a possible power supply issue unless there is a loose connection. Sounds to me like a capacitor breaking down in the supply, it can produce a short pulse at nominal power but not sustained nominal power.
    Someone else might be able to confirm my thoughts.
    Mar 2020
    22
    I think makercut is right. You should check your power supply issue.
    Do you have a user manual?
  1. 50w Laser Issue - Reduced power, advice needed
    By Devoreg in forum Tormach Personal CNC Mill
    Last Post: 04-28-2016, 01:47 AM
  2. 60w Chinese Laser cutter No power
    By Bpmarmstrong in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 08-28-2015, 01:47 AM
  3. Chinese laser cutter issue
    By ariemeir in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 06-04-2014, 11:24 AM
  4. Laser cutter power loose problem
    By Birhan in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 05-25-2010, 09:19 AM
