586,106 active members*
2,996 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Haas Mills > Very Slow 4th Axis even with G93
Results 1 to 6 of 6
    Jan 2012
    14
    Hello all,
    I'm trying to get my HAAS TM-3P up and running, we have a CAM program that exports purely X,Y,Z coordinates, after some manipulation I'm able to get it to a workable X,Z,A system.
    It's a high crossover spiral cut, but my 4th axis runs very choppy, almost as it's waiting for an axis to catch up.
    Our old machines (Non-Haas) use to run the code no problem using just G1 commands.
    I've tried G1 and G93 commands along with changing feedrates and I still have the same cut speed, irrelevant of F rate.
    Here is a snippet, I'm running with out a cutting tool, just focusing on speeding the 4th axis up.
    When I do a cut off at the end of the part it's very fast.
    It takes about 30 seconds to travel 1mm on the X-axis
    Thank you all.
    G91
    G21
    T2 M6
    G0 Y-254.
    G0 X-478.66
    S5900 M3
    G92 A0.0
    G1 Z-150. A-360.00 F500.0
    G0 Z-17.9
    G91 G28 G00 A0.
    G90
    G92 Z0.0
    G04 P1.0
    G93 F40.0
    X-478.66 Z-17.9 A0.0
    X-478.64 Z-17.9 A-4.0
    X-478.62 Z-17.9 A-8.0
    X-478.61 Z-17.9 A-12.0
    X-478.59 Z-17.9 A-16.0
    X-478.57 Z-17.9 A-20.0
    X-478.55 Z-17.9 A-24.0
    X-478.54 Z-17.9 A-28.0
    X-478.52 Z-17.9 A-32.0
    X-478.50 Z-17.9 A-36.0
    X-478.48 Z-17.9 A-40.0
    X-478.46 Z-17.9 A-44.0
    X-478.45 Z-17.9 A-48.0
    X-478.43 Z-17.9 A-52.0
    X-478.41 Z-17.9 A-56.0
    X-478.39 Z-17.9 A-60.0
    X-478.38 Z-17.9 A-64.0
    X-478.36 Z-17.9 A-68.0
    X-478.34 Z-17.9 A-72.0
    X-478.32 Z-17.9 A-76.0
    X-478.30 Z-17.9 A-80.0
    X-478.29 Z-17.9 A-84.0
    X-478.27 Z-17.9 A-88.0
    X-478.25 Z-17.9 A-92.0
    X-478.23 Z-17.9 A-96.0
    X-478.22 Z-17.9 A-100.0
    Feb 2008
    586
    Re: Very Slow 4th Axis even with G93
    hi....
    IIRC, F40. is supposed to try and move to the next place in .025 seconds. Start with F.5 (2 seconds) and see what happens. You could also put a G1 with that G93, as you're currently in G00 during what are supposed to be feed moves.
    Jan 2012
    14
    That actually did change things a bit. The federate variable does have a physical change now. It appears if I bump it past F500. It gets very jerky again. I'm also working in mm, I do have my machine parameters set up for that as well.
    Here is an updated snippet.
    G91
    G21
    T2 M6
    G0 Y-254.
    G0 X-478.66
    S5900 M3
    G92 A0.0
    G01 Z-150. A-360.00 F5000.0
    G91 G28 G00 A0.
    G90
    G0 Z-17.9 X-478.66 F1000.
    G04 P1.0
    G01 G93 F500. X-478.66 Z-17.9 A0.0
    G01 G93 F500. X-478.64 Z-17.9 A-4.0
    G01 G93 F500. X-478.62 Z-17.9 A-8.0
    G01 G93 F500. X-478.61 Z-17.9 A-12.0
    G01 G93 F500. X-478.59 Z-17.9 A-16.0
    G01 G93 F500. X-478.57 Z-17.9 A-20.0
    G01 G93 F500. X-478.55 Z-17.9 A-24.0
    G01 G93 F500. X-478.54 Z-17.9 A-28.0
    G01 G93 F500. X-478.52 Z-17.9 A-32.0
    G01 G93 F500. X-478.50 Z-17.9 A-36.0
    G01 G93 F500. X-478.48 Z-17.9 A-40.0
    G01 G93 F500. X-478.46 Z-17.9 A-44.0
    G01 G93 F500. X-478.45 Z-17.9 A-48.0
    G01 G93 F500. X-478.43 Z-17.9 A-52.0
    G01 G93 F500. X-478.41 Z-17.9 A-56.0
    G01 G93 F500. X-478.39 Z-17.9 A-60.0
    G01 G93 F500. X-478.38 Z-17.9 A-64.0
    G01 G93 F500. X-478.36 Z-17.9 A-68.0
    G01 G93 F500. X-478.34 Z-17.9 A-72.0
    G01 G93 F500. X-478.32 Z-17.9 A-76.0
    G01 G93 F500. X-478.30 Z-17.9 A-80.0
    G01 G93 F500. X-478.29 Z-17.9 A-84.0
    G01 G93 F500. X-478.27 Z-17.9 A-88.0
    G01 G93 F500. X-478.25 Z-17.9 A-92.0
    G01 G93 F500. X-478.23 Z-17.9 A-96.0
    G01 G93 F500. X-478.22 Z-17.9 A-100.0
    May 2013
    142
    Disengage your 4th axis brake. It may be engaging and disengaging in between moves.
    Jan 2012
    14
    Quote Originally Posted by Billetgrip View Post
    I threw an M11 command in the begging of the code, I still have the same issue.
    Thanks I'll keep the M11 in there for future troubleshooting sake
    Nov 2010
    73
    The program runs a large number of lines of code at a time. Maybe you can help the optional high-speed milling.
    You can also try to change the setting value 191.
    191 Default Smoothness
    This setting may be set to ROUGH, MEDIUM, or FINISH and uses parameters 302, 303, 314, 749, and 750-754 and
    G187 to set the smoothness and a maximum corner rounding factor. The default values are used when not overrid-
    den by a G187 command.
  1. Slave axis slow.
    By rbraeking in forum Mach Software (ArtSoft software)
    Last Post: 02-04-2017, 01:26 PM
  2. Fast in XY Axis, Slow in XZ, Why??
    By richiegore in forum Mach Software (ArtSoft software)
    Last Post: 05-18-2011, 11:18 PM
  3. 4th Axis very slow
    By irv in forum Syil Products
    Last Post: 12-14-2009, 07:30 PM
  4. 4th axis G1 runs too slow
    By slowbob in forum Mach Mill
    Last Post: 04-18-2009, 06:37 AM
  5. Axis Slow Down
    By dighsx in forum Xylotex
    Last Post: 05-31-2006, 02:15 PM
