Hi all,
Is the plugin compatible with 10hp 7.5kw GT series Huanyang VFD?
- Blaise
Hi all,
- Blaise
Oh! ok!!! Wow! You’re all over the place! I will give ModBusEZ a try!
I’ll keep you posted!
Many thanks!
- Blaise
Dan,
Have you updated the plugin for the new 64bit version of UCCNC?
There is no immediate need to update for latest UCCNC version 1.2103... HY12 works fine. Had problems with 1.2102 due to the .NET4 implemented but was fixed in newest UCCNC version. The only update needed for any older plugin is to compile with anyCPU and HY12 was. I only tested in demo mode but will test on machine today.
Dan
Oh, I didn't realize that you were already using AnyCPU. Thanks..
Hi Guys,
I've just purchased UCCNC and the 300eth to replace my MACH3 configuration, as well as the 2017 screenset. Having done so, I installed the latest HYPLUGIN.DLL with some success. With the initial installation on 2017, the spindle would not turn on. I loaded MACH3, which was already able to turn the spindle on, and it worked as I expected. I loaded UCCNC/2017 again, and the spindle would start but I could not control the speed with the slider. I don't remember if an "s10000" command changed the speed or not :-( I loaded the default UCCNC screenset, reconfigured HYPLUGIN, and it worked. Went back to UCCNC/2017, nothing. Went back to default, nothing.
help? any clues?
Many thanks,
Rick Van Norman
In the 2017 Screenset, you need to change the field number of the RPM DRO from 870 to 2451.
As for the slider, it was probably due to the commanded rpm being too low. The slider will not increase the speed above the commanded rpm, unless you edit the slider parameters.
Thanks Gerry!
That exactly fixed my problem. It wasn't clear that the RPM DRO value needed to be changed.
Is that only to make this work under the 2017 screenset?
Thanks again!
rick
The screenset was created before DRO 2451 was added to UCCNC. At some point, the plugin was changed to require the 2451 DRO (Overridden RPM).
The plugin wont work in any screen that doesn't have DRO 2451.
Aaarrrggghh!
As previously noted, I did get the system working.
Mostly.
About half the time, the spindle doesn't turn on. Seemingly randomly. Then, just as randomly, it turns back on.
Just now,
1. restart windows
2. start UCCNC
3. issue S10000
4. press "spindle cw (m3)". led came on.
5. nothing.
6. press "spindle cw (m3)" again. led went off
7. repeat 3 to 6 several times with different speed values. nothing
8. open device manager to make sure windows had not re-assigned com port. it hadn't
9. open configure plugins, and view the settings for HYPLUGIN. all looks same as previous and just fine
10. try to turn spindle on again;
11. WORKS.
12. on and off, works.
13. HELP!?!?
Any notions or ideas about how to debug it?
rick
First, let me mention that the hardware (serial adapter, computer, etc) has not changed since I was using this under MACH3. No failures there ever.
My current profile is attached, as are the driver details.
Thanks!
rick
JBtek USB to RS485 Converter Adapter ch340T chip 64-bit Window 7 Supported
by JBtek
Link: http://a.co/6kkpggQ
Attachment 389356
Attachment 389358
[Screensetsettings]
mainscreenfilename=2017
splashscreen=0
[axessettingscontrolX]
Axisenabled=True
Stepportnumber=1
Steppinnumber=4
Steppinnegate=True
Dirpinnumber=5
Dirportnumber=1
Dirpinnegate=True
Enapinnumber=0
Enaportnumber=0
Enapinnegate=False
Limitminuspinnumber=12
Limitminuspinnegate=False
Limitpluspinnumber=12
Limitpluspinnegate=False
Homepinnumber=12
Homepinnegate=False
Homedirectionpositive=False
Homeautozero=True
Homingvalue=0
Homingspeedup=60
Homingspeeddown=30
Stepsperunit=1527.88745
Velocity=600
Acceleration=10
Softlimitpositive=49.5
Softlimitnegative=0
Backlashenable=False
Backlashdistance=0
Slaveaxis=None
Homeportnumber=1
Limitminusportnumber=1
Limitplusportnumber=1
Compaccel=1200
[axessettingscontrolY]
Axisenabled=True
Stepportnumber=1
Steppinnumber=6
Steppinnegate=True
Dirpinnumber=7
Dirportnumber=1
Dirpinnegate=False
Enapinnumber=0
Enaportnumber=0
Enapinnegate=False
Limitminuspinnumber=13
Limitminuspinnegate=True
Limitpluspinnumber=13
Limitpluspinnegate=True
Homepinnumber=13
Homepinnegate=True
Homeautozero=True
Homingvalue=0
Homingspeedup=60
Homingspeeddown=30
Velocity=600
Acceleration=10
Softlimitnegative=0
Backlashdistance=0
Slaveaxis=A
Homeportnumber=1
Compaccel=240
[axessettingscontrolZ]
Axisenabled=True
Stepportnumber=1
Steppinnumber=2
Steppinnegate=True
Dirpinnumber=3
Dirportnumber=1
Dirpinnegate=False
Enapinnumber=0
Enaportnumber=0
Enapinnegate=False
Homepinnumber=12
Homepinnegate=False
Homedirectionpositive=True
Homeautozero=True
Homingvalue=0
Homingspeedup=39.996
Homingspeeddown=19.998
Stepsperunit=6400
Velocity=199.98
Acceleration=10
Softlimitpositive=0
Softlimitnegative=-6
Backlashdistance=0
Slaveaxis=None
Homeportnumber=1
Compaccel=240
[axessettingscontrolA]
Axisenabled=True
Stepportnumber=1
Steppinnumber=8
Steppinnegate=True
Dirpinnumber=9
Dirportnumber=1
Dirpinnegate=False
Enapinnumber=0
Enaportnumber=0
Enapinnegate=False
Limitminuspinnumber=15
Limitpluspinnumber=15
Homepinnumber=15
Homepinnegate=True
Homeautozero=True
Homingvalue=0
Homingspeedup=60
Homingspeeddown=30
Velocity=600
Acceleration=10
Softlimitnegative=0
Backlashdistance=0
Homeportnumber=1
Compaccel=240
[axessettingscontrolB]
Axisenabled=False
Stepportnumber=0
Steppinnumber=0
Steppinnegate=False
Dirpinnumber=0
Dirportnumber=0
Dirpinnegate=False
Enapinnumber=0
Enaportnumber=0
Enapinnegate=False
Limitminuspinnumber=0
Limitpluspinnumber=0
Homepinnumber=0
Homepinnegate=False
Homeautozero=True
Homingvalue=0
Homingspeedup=24
Homingspeeddown=12
Stepsperunit=0.0001
Velocity=120
Acceleration=4
Softlimitpositive=100
Softlimitnegative=-100
Backlashdistance=0
Homeportnumber=0
Limitminusportnumber=0
Limitplusportnumber=0
Compaccel=240
[axessettingscontrolC]
Axisenabled=False
Steppinnumber=0
Stepportnumber=0
Steppinnegate=False
Dirpinnumber=0
Dirportnumber=0
Dirpinnegate=False
Enapinnumber=0
Enaportnumber=0
Enapinnegate=False
Homepinnumber=0
Homepinnegate=False
Homeautozero=True
Homingvalue=0
Homingspeedup=24
Homingspeeddown=12
Stepsperunit=0.0001
Velocity=120
Acceleration=4
Backlashdistance=0
Homeportnumber=0
Compaccel=240
[Spindlesetupsettings]
IsSpindleinPWMMode=True
SpindlePWMoutpin=0
SpindlePWMoutpinnegate=False
SpindlePWMdirpin=0
SpindlePWMdirpinnegate=False
SpindlePWMfrequency=200
SpindlePWMminpercent=0
SpindlePWMmaxpercent=100
Spindlesteppin=0
Spindlesteppinnegate=False
Spindledirpin=0
Spindledirpinnegate=False
Spindlestepsperunit=500
Spindleacceleration=200
Spindleminvelocity=8000
Spindlemaxvelocity=24000
Spindlerelaysenabled=False
M3relaypin=0
M3relaypinnegate=False
M4relaypin=0
M4relaypinnegate=False
M3ondelay=12000
M3offdelay=10000
M4ondelay=8000
M4offdelay=10000
Floodmistrelaysenabled=False
M7relaypin=0
M7relaypinnegate=False
M8relaypin=0
M8relaypinnegate=False
M7ondelay=0
M8ondelay=0
M9delay=0
SpindlePWMoutport=0
SpindlePWMdirport=0
Spindlestepport=0
Spindledirport=0
M3relayport=0
M4relayport=0
M7relayport=0
M8relayport=0
EncoderApin=0
EncoderAport=0
EncoderBpin=0
EncoderBport=0
Encoderreversedirection=False
EncoderPPR=400
Pulleyratio1=1
Pulleyminvel1=1
Pulleymaxvel1=1
Pulleyinuse=1
Pulleyratio2=1
Pulleyminvel2=1
Pulleymaxvel2=1
Pulleyratio3=1
Pulleyminvel3=1
Pulleymaxvel3=1
Pulleyratio4=1
Pulleyminvel4=1
Pulleymaxvel4=1
Pulleyratio5=1
Pulleyminvel5=1
Pulleymaxvel5=1
Pulleyratio6=1
Pulleyminvel6=1
Pulleymaxvel6=1
Pulleyratio7=1
Pulleyminvel7=1
Pulleymaxvel7=1
Pulleyratio8=1
Pulleyminvel8=1
Pulleymaxvel8=1
Pulleyratio9=1
Pulleyminvel9=1
Pulleymaxvel9=1
Pulleyratio10=1
Pulleyminvel10=1
Pulleymaxvel10=1
Pulleyratio11=1
Pulleyminvel11=1
Pulleymaxvel11=1
Pulleyratio12=1
Pulleyminvel12=1
Pulleymaxvel12=1
Pulleyratio13=1
Pulleyminvel13=1
Pulleymaxvel13=1
Pulleyratio14=1
Pulleyminvel14=1
Pulleymaxvel14=1
Pulleyratio15=1
Pulleyminvel15=1
Pulleymaxvel15=1
Usepulleys=False
[Generalsettings]
Constantvelocitymode=True
Stopatangle=89
Lookaheadlines=300
Softlimitsenable=False
Homesequence1=Z
Homesequence2=X
Homesequence3=Y
Homesequence4=None
Homesequence5=None
Homesequence6=None
Linearerror=0.03
Cornerserror=0.03
USBbuffersize=0.1
POSDROsdigits=3
Doontoolchange=0
MaxLinearaddlenght=1
MaxLinearunificationlenght=2
Kernelfreq=0
SafeZ=1
G73_backoff=0.4
Maximisescreenonstartup=False
Dwellinseconds=False
Runmodewhenunknowngcode=0
Softlimitsgcodeprecheck=False
Precompilemacrosonstartup=False
Arcradiustolerance=0.1
ResetG68onfileload=False
ResetG51onfileload=False
[IOsetupsettings]
Estoppinnumber=11
Estoppinnegate=False
Probepinnumber=10
Probepinnegate=True
Chargepumppinnumber=0
Chargepumppinnegate=False
Chargepumplasermodeon=False
Chargepumpalwayson=False
CurrentHiLopinnumber=0
CurrentHiLopinnegate=False
Indexpinnumber=0
Indexprescaler=1
THCenable=False
THConpin=0
THConpinnegate=False
THCuppin=0
THCuppinnegate=False
THCdownpin=0
THCdownpinnegate=False
THCmin=0.2
THCmax=1
THCfeed=39.996
THCalwayson=False
THCondelay=0
Estopportnumber=1
Chargepumpportnumber=0
CurrentHiLoportnumber=0
Indexportnumber=0
Probeportnumber=1
THConport=0
THCupport=0
THCdownport=0
MPG1pinA=0
MPG1pinB=0
MPG1portA=0
MPG1portB=0
MPG1prescaler=1
MPG1filter=10
MPG1speedmultiplier=10
FROchannel=0
SROchannel=0
JROchannel=0
FROminpercent=0
FROmaxpercent=0
SROminpercent=0
SROmaxpercent=0
JROminpercent=0
JROmaxpercent=0
SPPWMchannel=0
Ana1invarnum=0
Ana2invarnum=0
Ana1outvarnum=0
Ana2outvarnum=0
MPG1attachtoJRO=False
Laseroutputpinnumber=0
Laseroutputportnumber=0
Laseroutputpinnegate=False
THCantidiveenable=False
THCantidivepercent=0
Plasmapierceheight=0
Chargepump2pinnumber=0
Chargepump2portnumber=0
Chargepump2pinnegate=False
Probepin2number=0
Probeport2number=0
Probepin2negate=False
THCdelayenable=False
THCenableoutpin=0
THCenableoutport=0
THCenableoutpinnegate=False
THCantidiveoutpin=0
THCantidiveoutport=0
THCantidiveoutpinnegate=False
THCantidownoutpin=0
THCantidownoutport=0
THCantidownoutpinnegate=False
THCantidownenable=False
Ana3invarnum=0
Ana4invarnum=0
Ana3outvarnum=0
Ana4outvarnum=0
[Appearancesetupsettings]
2DTLCmarker=True
Viewerundonepathcolor=3381759
Viewerdonepathcolor=-5374161
Viewerrapidpathcolor=16711680
ViewerTCPmarkercolor=16776960
ViewerBackgroundcolor=0
Viewerboundariescolor=16777215
GVgcodecolors=-16777216
GVmcodecolors=-233
GVscodecolors=-32513
GVfcodecolors=-21931
GVbackgroundcolor=-12698050
GVactualcodecolor=-16777216
GVactualcodemidlinescolor=-16777216
GVnotinterpretedcodecolor=16711680
GVaxiswordcolor=-8323328
GVcoordinatecolor=-9250052
TCPcone=True
TCPcross=False
RotateTCPwithplaneselection=True
Showzeromark=True
Zeromarkcolor=-16711681
DROwarningcolor=-65536
rotationpointmarkcolor=-65536
Showrotationmark=True
Showtoolpathboundaries=True
Highlightcolor=-1
Showmessageonsoftlimits=True
ValidateTextfieldsonEnteronly=True
Disablejogpanelautopopup=True
ShowtoolpathZzeroplate=False
ZplateXextents=100
ZplateYextents=100
ZplateZposition=0
ZplateZpositiononbottom=False
ZplatePlateOpacity=25
ZplateColor=-65536
ZplateXgrid=10
ZplateYgrid=10
ZplateGridOpacity=25
ZplateGridColor=-1
ZplateShowSoftlimits=False
ZplateSoftlimitsColor=-16711936
ZplateSoftlimitsOpacity=100
[Tooltablevalues]
TooloffsetZ0=0
TooloffsetZ1=0
TooloffsetZ2=0
TooloffsetZ3=0
TooloffsetZ4=0
TooloffsetZ5=0
TooloffsetZ6=0
TooloffsetZ7=0
TooloffsetZ8=0
TooloffsetZ9=0
TooloffsetZ10=0
TooloffsetZ11=0
TooloffsetZ12=0
TooloffsetZ13=0
TooloffsetZ14=0
TooloffsetZ15=0
TooloffsetZ16=0
TooloffsetZ17=0
TooloffsetZ18=0
TooloffsetZ19=0
TooloffsetZ20=0
TooloffsetZ21=0
TooloffsetZ22=0
TooloffsetZ23=0
TooloffsetZ24=0
TooloffsetZ25=0
TooloffsetZ26=0
TooloffsetZ27=0
TooloffsetZ28=0
TooloffsetZ29=0
TooloffsetZ30=0
TooloffsetZ31=0
TooloffsetZ32=0
TooloffsetZ33=0
TooloffsetZ34=0
TooloffsetZ35=0
TooloffsetZ36=0
TooloffsetZ37=0
TooloffsetZ38=0
TooloffsetZ39=0
TooloffsetZ40=0
TooloffsetZ41=0
TooloffsetZ42=0
TooloffsetZ43=0
TooloffsetZ44=0
TooloffsetZ45=0
TooloffsetZ46=0
TooloffsetZ47=0
TooloffsetZ48=0
TooloffsetZ49=0
TooloffsetZ50=0
TooloffsetZ51=0
TooloffsetZ52=0
TooloffsetZ53=0
TooloffsetZ54=0
TooloffsetZ55=0
TooloffsetZ56=0
TooloffsetZ57=0
TooloffsetZ58=0
TooloffsetZ59=0
TooloffsetZ60=0
TooloffsetZ61=0
TooloffsetZ62=0
TooloffsetZ63=0
TooloffsetZ64=0
TooloffsetZ65=0
TooloffsetZ66=0
TooloffsetZ67=0
TooloffsetZ68=0
TooloffsetZ69=0
TooloffsetZ70=0
TooloffsetZ71=0
TooloffsetZ72=0
TooloffsetZ73=0
TooloffsetZ74=0
TooloffsetZ75=0
TooloffsetZ76=0
TooloffsetZ77=0
TooloffsetZ78=0
TooloffsetZ79=0
TooloffsetZ80=0
TooloffsetZ81=0
TooloffsetZ82=0
TooloffsetZ83=0
TooloffsetZ84=0
TooloffsetZ85=0
TooloffsetZ86=0
TooloffsetZ87=0
TooloffsetZ88=0
TooloffsetZ89=0
TooloffsetZ90=0
TooloffsetZ91=0
TooloffsetZ92=0
TooloffsetZ93=0
TooloffsetZ94=0
TooloffsetZ95=0
TooloffsetZ96=0
[Workoffset_G54]
WorkoffsetX=9.907798
WorkoffsetY=6.095344
WorkoffsetZ=-4.680063
WorkoffsetA=0
WorkoffsetB=0
WorkoffsetC=0
[Workoffset_G55]
WorkoffsetX=0
WorkoffsetY=0
WorkoffsetZ=0
WorkoffsetA=0
WorkoffsetB=0
WorkoffsetC=0
[Workoffset_G56]
WorkoffsetX=0
WorkoffsetY=0
WorkoffsetZ=0
WorkoffsetA=0
WorkoffsetB=0
WorkoffsetC=0
[Workoffset_G57]
WorkoffsetX=0
WorkoffsetY=0
WorkoffsetZ=0
WorkoffsetA=0
WorkoffsetB=0
WorkoffsetC=0
[Workoffset_G58]
WorkoffsetX=0
WorkoffsetY=0
WorkoffsetZ=0
WorkoffsetA=0
WorkoffsetB=0
WorkoffsetC=0
[Workoffset_G59]
WorkoffsetX=0
WorkoffsetY=0
WorkoffsetZ=0
WorkoffsetA=0
WorkoffsetB=0
WorkoffsetC=0
[Machinecoords]
MachinecoordsX=9.907798
MachinecoordsY=31.86164
MachinecoordsZ=-1.415469
MachinecoordsA=0
MachinecoordsB=0
MachinecoordsC=0
[Tooloffsetcoords]
TooloffsetZ=0
[Systemmessages]
Message0=Valid license key was not found! Application will run in demo mode!
Message1=Firmware update done!
Message2=No UC100 connection was found! Application will run in demo mode!
Message3=Firmware update in progress! Please wait and do not close the application...
Message4=The application lost the connection with the motion controller device. [nl] Check the connection. The application is closing now! [nl] Save offsets?
Message5=A machine axis position software limit was reached. The axis was now stopped.
Message6=The reset logic of the software is active! [nl] Remove the reset condition with pressing the blinking reset button on the screen. [nl] If the reset condition cannot be removed can be due to an external e-stop button is pressed in or a limit switch on the machine tool is active. [nl] Please check the Diagnostics page for the input signals condition.
Message7=The current job workspace is out of the set software limits.[nl] Adjust the softlimits to fit the job extents or disable the softlimits.
Message8=The axis is disabled. To calibrate this axis enable the axis first.
Message9=An internal error occured. The application is closing now.
Message10=Enter a valid distance in absolute value!
Message11=The calculated steps per value was saved.
Message12=Please enter valid data.
Message13=Active fixture:
Message14=Are you sure you want to close?
Message15=
Message16=
Message17=
Message18=
Message19=
Message20=
Message21=
Message22=
Message23=
Message24=
Message25=
Message26=
Message27=The Default profile cannot be deleted!
Message28=File error.Could not delete the profile's macro library!
Message29=Do you really want to delete the profile :
Message30=File error.Could not copy default macros to profile!
Message31=was loaded!
Message32=The axis calibration makes a measurement to calibrate the steps per units resolution value for the machine axis. To abort and close this window press the cancel button.
Message33=Mark the current position of the machine axis. Set the distance and the feedrate on this page and press the OK button to make a movement.
Message34=Measure the travel distance on the machine axis from the previously marked point to the current point. Type the measured value to the field below and press OK.
Message35=The new steps per value was calculated and written to the below field. To save the new value press OK. The process is then finished.
Message36=Switch spindle on first
Message37=Move Z-axis first to safeZ height:
Message38=Make movement with safeZ to:
Message39=Start position(Units):
Message40=Actual steps per Unit:
Message41=Distance to move(Units):
Message42=Feed rate(Units/min):
Message43=Distance measured(Units):
Message44=Steps per Units calculated value:
Message45=The software limits is lower than the safeZ height. Execute the command anyways?
Message46=was created!
[Hotkeysettings]
Keycode1=39
Buttoncode1=147
Keycode2=37
Buttoncode2=148
Keycode3=38
Buttoncode3=149
Keycode4=40
Buttoncode4=150
Keycode5=33
Buttoncode5=151
Keycode6=34
Buttoncode6=152
Keycode7=45
Buttoncode7=153
Keycode8=46
Buttoncode8=154
Keycode9=81
Buttoncode9=155
Keycode10=65
Buttoncode10=156
Keycode11=87
Buttoncode11=157
Keycode12=83
Buttoncode12=158
Keycode13=27
Buttoncode13=130
Keycode14=0
Buttoncode14=0
Keycode15=0
Buttoncode15=0
Keycode16=0
Buttoncode16=0
Keycode17=0
Buttoncode17=0
Keycode18=0
Buttoncode18=0
Keycode19=0
Buttoncode19=0
Keycode20=0
Buttoncode20=0
Keycode21=0
Buttoncode21=0
Keycode22=0
Buttoncode22=0
Keycode23=0
Buttoncode23=0
Keycode24=0
Buttoncode24=0
Keycode25=0
Buttoncode25=0
Keycode26=0
Buttoncode26=0
Keycode27=0
Buttoncode27=0
Keycode28=0
Buttoncode28=0
Keycode29=0
Buttoncode29=0
Keycode30=0
Buttoncode30=0
Keycode31=0
Buttoncode31=0
Keycode32=0
Buttoncode32=0
Keycode33=0
Buttoncode33=0
Keycode34=0
Buttoncode34=0
Keycode35=0
Buttoncode35=0
Keycode36=0
Buttoncode36=0
Keycode37=0
Buttoncode37=0
Keycode38=0
Buttoncode38=0
Keycode39=0
Buttoncode39=0
Keycode40=0
Buttoncode40=0
Keycode41=0
Buttoncode41=0
Keycode42=0
Buttoncode42=0
Keycode43=0
Buttoncode43=0
Keycode44=0
Buttoncode44=0
Keycode45=0
Buttoncode45=0
Keycode46=0
Buttoncode46=0
Keycode47=0
Buttoncode47=0
Keycode48=0
Buttoncode48=0
Keycode49=0
Buttoncode49=0
Keycode50=0
Buttoncode50=0
Keycode51=0
Buttoncode51=0
Keycode52=0
Buttoncode52=0
Keycode53=0
Buttoncode53=0
Keycode54=0
Buttoncode54=0
Keycode55=0
Buttoncode55=0
Keycode56=0
Buttoncode56=0
Keycode57=0
Buttoncode57=0
Keycode58=0
Buttoncode58=0
Keycode59=0
Buttoncode59=0
Keycode60=0
Buttoncode60=0
Keycode61=0
Buttoncode61=0
Keycode62=0
Buttoncode62=0
Keycode63=0
Buttoncode63=0
Keycode64=0
Buttoncode64=0
Keycode65=0
Buttoncode65=0
Keycode66=0
Buttoncode66=0
Keycode67=0
Buttoncode67=0
Keycode68=0
Buttoncode68=0
Keycode69=0
Buttoncode69=0
Keycode70=0
Buttoncode70=0
Keycode71=0
Buttoncode71=0
Keycode72=0
Buttoncode72=0
Keycode73=0
Buttoncode73=0
Keycode74=0
Buttoncode74=0
Keycode75=0
Buttoncode75=0
Keycode76=0
Buttoncode76=0
Keycode77=0
Buttoncode77=0
Keycode78=0
Buttoncode78=0
Keycode79=0
Buttoncode79=0
Keycode80=0
Buttoncode80=0
Keycode81=0
Buttoncode81=0
Keycode82=0
Buttoncode82=0
Keycode83=0
Buttoncode83=0
Keycode84=0
Buttoncode84=0
Keycode85=0
Buttoncode85=0
Keycode86=0
Buttoncode86=0
Keycode87=0
Buttoncode87=0
Keycode88=0
Buttoncode88=0
Keycode89=0
Buttoncode89=0
Keycode90=0
Buttoncode90=0
Keycode91=0
Buttoncode91=0
Keycode92=0
Buttoncode92=0
Keycode93=0
Buttoncode93=0
Keycode94=0
Buttoncode94=0
Keycode95=0
Buttoncode95=0
Keycode96=0
Buttoncode96=0
[Inputtriggersettings]
Pin1=0
Port1=0
Buttoncode1=0
Activelow1=False
Pin2=0
Port2=0
Buttoncode2=0
Activelow2=False
Pin3=0
Port3=0
Buttoncode3=0
Activelow3=False
Pin4=0
Port4=0
Buttoncode4=0
Activelow4=False
Pin5=0
Port5=0
Buttoncode5=0
Activelow5=False
Pin6=0
Port6=0
Buttoncode6=0
Activelow6=False
Pin7=0
Port7=0
Buttoncode7=0
Activelow7=False
Pin8=0
Port8=0
Buttoncode8=0
Activelow8=False
Pin9=0
Port9=0
Buttoncode9=0
Activelow9=False
Pin10=0
Port10=0
Buttoncode10=0
Activelow10=False
Pin11=0
Port11=0
Buttoncode11=0
Activelow11=False
Pin12=0
Port12=0
Buttoncode12=0
Activelow12=False
Pin13=0
Port13=0
Buttoncode13=0
Activelow13=False
Pin14=0
Port14=0
Buttoncode14=0
Activelow14=False
Pin15=0
Port15=0
Buttoncode15=0
Activelow15=False
Pin16=0
Port16=0
Buttoncode16=0
Activelow16=False
Pin17=0
Port17=0
Buttoncode17=0
Activelow17=False
Pin18=0
Port18=0
Buttoncode18=0
Activelow18=False
Pin19=0
Port19=0
Buttoncode19=0
Activelow19=False
Pin20=0
Port20=0
Buttoncode20=0
Activelow20=False
Pin21=0
Port21=0
Buttoncode21=0
Activelow21=False
Pin22=0
Port22=0
Buttoncode22=0
Activelow22=False
Pin23=0
Port23=0
Buttoncode23=0
Activelow23=False
Pin24=0
Port24=0
Buttoncode24=0
Activelow24=False
Pin25=0
Port25=0
Buttoncode25=0
Activelow25=False
Pin26=0
Port26=0
Buttoncode26=0
Activelow26=False
Pin27=0
Port27=0
Buttoncode27=0
Activelow27=False
Pin28=0
Port28=0
Buttoncode28=0
Activelow28=False
Pin29=0
Port29=0
Buttoncode29=0
Activelow29=False
Pin30=0
Port30=0
Buttoncode30=0
Activelow30=False
Pin31=0
Port31=0
Buttoncode31=0
Activelow31=False
Pin32=0
Port32=0
Buttoncode32=0
Activelow32=False
Pin33=0
Port33=0
Buttoncode33=0
Activelow33=False
Pin34=0
Port34=0
Buttoncode34=0
Activelow34=False
Pin35=0
Port35=0
Buttoncode35=0
Activelow35=False
Pin36=0
Port36=0
Buttoncode36=0
Activelow36=False
Pin37=0
Port37=0
Buttoncode37=0
Activelow37=False
Pin38=0
Port38=0
Buttoncode38=0
Activelow38=False
Pin39=0
Port39=0
Buttoncode39=0
Activelow39=False
Pin40=0
Port40=0
Buttoncode40=0
Activelow40=False
Pin41=0
Port41=0
Buttoncode41=0
Activelow41=False
Pin42=0
Port42=0
Buttoncode42=0
Activelow42=False
Pin43=0
Port43=0
Buttoncode43=0
Activelow43=False
Pin44=0
Port44=0
Buttoncode44=0
Activelow44=False
Pin45=0
Port45=0
Buttoncode45=0
Activelow45=False
Pin46=0
Port46=0
Buttoncode46=0
Activelow46=False
Pin47=0
Port47=0
Buttoncode47=0
Activelow47=False
Pin48=0
Port48=0
Buttoncode48=0
Activelow48=False
Pin49=0
Port49=0
Buttoncode49=0
Activelow49=False
Pin50=0
Port50=0
Buttoncode50=0
Activelow50=False
Pin51=0
Port51=0
Buttoncode51=0
Activelow51=False
Pin52=0
Port52=0
Buttoncode52=0
Activelow52=False
Pin53=0
Port53=0
Buttoncode53=0
Activelow53=False
Pin54=0
Port54=0
Buttoncode54=0
Activelow54=False
Pin55=0
Port55=0
Buttoncode55=0
Activelow55=False
Pin56=0
Port56=0
Buttoncode56=0
Activelow56=False
Pin57=0
Port57=0
Buttoncode57=0
Activelow57=False
Pin58=0
Port58=0
Buttoncode58=0
Activelow58=False
Pin59=0
Port59=0
Buttoncode59=0
Activelow59=False
Pin60=0
Port60=0
Buttoncode60=0
Activelow60=False
Pin61=0
Port61=0
Buttoncode61=0
Activelow61=False
Pin62=0
Port62=0
Buttoncode62=0
Activelow62=False
Pin63=0
Port63=0
Buttoncode63=0
Activelow63=False
Pin64=0
Port64=0
Buttoncode64=0
Activelow64=False
Pin65=0
Port65=0
Buttoncode65=0
Activelow65=False
Pin66=0
Port66=0
Buttoncode66=0
Activelow66=False
Pin67=0
Port67=0
Buttoncode67=0
Activelow67=False
Pin68=0
Port68=0
Buttoncode68=0
Activelow68=False
Pin69=0
Port69=0
Buttoncode69=0
Activelow69=False
Pin70=0
Port70=0
Buttoncode70=0
Activelow70=False
Pin71=0
Port71=0
Buttoncode71=0
Activelow71=False
Pin72=0
Port72=0
Buttoncode72=0
Activelow72=False
Pin73=0
Port73=0
Buttoncode73=0
Activelow73=False
Pin74=0
Port74=0
Buttoncode74=0
Activelow74=False
Pin75=0
Port75=0
Buttoncode75=0
Activelow75=False
Pin76=0
Port76=0
Buttoncode76=0
Activelow76=False
Pin77=0
Port77=0
Buttoncode77=0
Activelow77=False
Pin78=0
Port78=0
Buttoncode78=0
Activelow78=False
Pin79=0
Port79=0
Buttoncode79=0
Activelow79=False
Pin80=0
Port80=0
Buttoncode80=0
Activelow80=False
Pin81=0
Port81=0
Buttoncode81=0
Activelow81=False
Pin82=0
Port82=0
Buttoncode82=0
Activelow82=False
Pin83=0
Port83=0
Buttoncode83=0
Activelow83=False
Pin84=0
Port84=0
Buttoncode84=0
Activelow84=False
Pin85=0
Port85=0
Buttoncode85=0
Activelow85=False
Pin86=0
Port86=0
Buttoncode86=0
Activelow86=False
Pin87=0
Port87=0
Buttoncode87=0
Activelow87=False
Pin88=0
Port88=0
Buttoncode88=0
Activelow88=False
Pin89=0
Port89=0
Buttoncode89=0
Activelow89=False
Pin90=0
Port90=0
Buttoncode90=0
Activelow90=False
Pin91=0
Port91=0
Buttoncode91=0
Activelow91=False
Pin92=0
Port92=0
Buttoncode92=0
Activelow92=False
Pin93=0
Port93=0
Buttoncode93=0
Activelow93=False
Pin94=0
Port94=0
Buttoncode94=0
Activelow94=False
Pin95=0
Port95=0
Buttoncode95=0
Activelow95=False
Pin96=0
Port96=0
Buttoncode96=0
Activelow96=False
[Outputtriggersettings]
Pin1=0
Port1=0
LEDcode1=0
Invert1=False
Pin2=0
Port2=0
LEDcode2=0
Invert2=False
Pin3=0
Port3=0
LEDcode3=0
Invert3=False
Pin4=0
Port4=0
LEDcode4=0
Invert4=False
Pin5=0
Port5=0
LEDcode5=0
Invert5=False
Pin6=0
Port6=0
LEDcode6=0
Invert6=False
Pin7=0
Port7=0
LEDcode7=0
Invert7=False
Pin8=0
Port8=0
LEDcode8=0
Invert8=False
Pin9=0
Port9=0
LEDcode9=0
Invert9=False
Pin10=0
Port10=0
LEDcode10=0
Invert10=False
Pin11=0
Port11=0
LEDcode11=0
Invert11=False
Pin12=0
Port12=0
LEDcode12=0
Invert12=False
Pin13=0
Port13=0
LEDcode13=0
Invert13=False
Pin14=0
Port14=0
LEDcode14=0
Invert14=False
Pin15=0
Port15=0
LEDcode15=0
Invert15=False
Pin16=0
Port16=0
LEDcode16=0
Invert16=False
Pin17=0
Port17=0
LEDcode17=0
Invert17=False
Pin18=0
Port18=0
LEDcode18=0
Invert18=False
Pin19=0
Port19=0
LEDcode19=0
Invert19=False
Pin20=0
Port20=0
LEDcode20=0
Invert20=False
Pin21=0
Port21=0
LEDcode21=0
Invert21=False
Pin22=0
Port22=0
LEDcode22=0
Invert22=False
Pin23=0
Port23=0
LEDcode23=0
Invert23=False
Pin24=0
Port24=0
LEDcode24=0
Invert24=False
Pin25=0
Port25=0
LEDcode25=0
Invert25=False
Pin26=0
Port26=0
LEDcode26=0
Invert26=False
Pin27=0
Port27=0
LEDcode27=0
Invert27=False
Pin28=0
Port28=0
LEDcode28=0
Invert28=False
Pin29=0
Port29=0
LEDcode29=0
Invert29=False
Pin30=0
Port30=0
LEDcode30=0
Invert30=False
Pin31=0
Port31=0
LEDcode31=0
Invert31=False
Pin32=0
Port32=0
LEDcode32=0
Invert32=False
Pin33=0
Port33=0
LEDcode33=0
Invert33=False
Pin34=0
Port34=0
LEDcode34=0
Invert34=False
Pin35=0
Port35=0
LEDcode35=0
Invert35=False
Pin36=0
Port36=0
LEDcode36=0
Invert36=False
Pin37=0
Port37=0
LEDcode37=0
Invert37=False
Pin38=0
Port38=0
LEDcode38=0
Invert38=False
Pin39=0
Port39=0
LEDcode39=0
Invert39=False
Pin40=0
Port40=0
LEDcode40=0
Invert40=False
Pin41=0
Port41=0
LEDcode41=0
Invert41=False
Pin42=0
Port42=0
LEDcode42=0
Invert42=False
Pin43=0
Port43=0
LEDcode43=0
Invert43=False
Pin44=0
Port44=0
LEDcode44=0
Invert44=False
Pin45=0
Port45=0
LEDcode45=0
Invert45=False
Pin46=0
Port46=0
LEDcode46=0
Invert46=False
Pin47=0
Port47=0
LEDcode47=0
Invert47=False
Pin48=0
Port48=0
LEDcode48=0
Invert48=False
Pin49=0
Port49=0
LEDcode49=0
Invert49=False
Pin50=0
Port50=0
LEDcode50=0
Invert50=False
Pin51=0
Port51=0
LEDcode51=0
Invert51=False
Pin52=0
Port52=0
LEDcode52=0
Invert52=False
Pin53=0
Port53=0
LEDcode53=0
Invert53=False
Pin54=0
Port54=0
LEDcode54=0
Invert54=False
Pin55=0
Port55=0
LEDcode55=0
Invert55=False
Pin56=0
Port56=0
LEDcode56=0
Invert56=False
Pin57=0
Port57=0
LEDcode57=0
Invert57=False
Pin58=0
Port58=0
LEDcode58=0
Invert58=False
Pin59=0
Port59=0
LEDcode59=0
Invert59=False
Pin60=0
Port60=0
LEDcode60=0
Invert60=False
Pin61=0
Port61=0
LEDcode61=0
Invert61=False
Pin62=0
Port62=0
LEDcode62=0
Invert62=False
Pin63=0
Port63=0
LEDcode63=0
Invert63=False
Pin64=0
Port64=0
LEDcode64=0
Invert64=False
Pin65=0
Port65=0
LEDcode65=0
Invert65=False
Pin66=0
Port66=0
LEDcode66=0
Invert66=False
Pin67=0
Port67=0
LEDcode67=0
Invert67=False
Pin68=0
Port68=0
LEDcode68=0
Invert68=False
Pin69=0
Port69=0
LEDcode69=0
Invert69=False
Pin70=0
Port70=0
LEDcode70=0
Invert70=False
Pin71=0
Port71=0
LEDcode71=0
Invert71=False
Pin72=0
Port72=0
LEDcode72=0
Invert72=False
Pin73=0
Port73=0
LEDcode73=0
Invert73=False
Pin74=0
Port74=0
LEDcode74=0
Invert74=False
Pin75=0
Port75=0
LEDcode75=0
Invert75=False
Pin76=0
Port76=0
LEDcode76=0
Invert76=False
Pin77=0
Port77=0
LEDcode77=0
Invert77=False
Pin78=0
Port78=0
LEDcode78=0
Invert78=False
Pin79=0
Port79=0
LEDcode79=0
Invert79=False
Pin80=0
Port80=0
LEDcode80=0
Invert80=False
Pin81=0
Port81=0
LEDcode81=0
Invert81=False
Pin82=0
Port82=0
LEDcode82=0
Invert82=False
Pin83=0
Port83=0
LEDcode83=0
Invert83=False
Pin84=0
Port84=0
LEDcode84=0
Invert84=False
Pin85=0
Port85=0
LEDcode85=0
Invert85=False
Pin86=0
Port86=0
LEDcode86=0
Invert86=False
Pin87=0
Port87=0
LEDcode87=0
Invert87=False
Pin88=0
Port88=0
LEDcode88=0
Invert88=False
Pin89=0
Port89=0
LEDcode89=0
Invert89=False
Pin90=0
Port90=0
LEDcode90=0
Invert90=False
Pin91=0
Port91=0
LEDcode91=0
Invert91=False
Pin92=0
Port92=0
LEDcode92=0
Invert92=False
Pin93=0
Port93=0
LEDcode93=0
Invert93=False
Pin94=0
Port94=0
LEDcode94=0
Invert94=False
Pin95=0
Port95=0
LEDcode95=0
Invert95=False
Pin96=0
Port96=0
LEDcode96=0
Invert96=False
[CAMsettings]
Tooldia=0
Startdepth=0
Cutdepth=0
Cutperpass=0
SafeZ=0
Feedrate=0
Tooloverlap=0
Plungerate=0
Spindlespeed=0
Arctolerance=0.01
[Laserengraveplugin]
workpiecewidth=50
workpieceheight=50
keepaspectratio=True
Yscandistance=0.2
Feedrate=1000
Originsetting=7
[Plugins_enabled]
Debugger.dll=False
Diagnostics.dll=False
Laserengrave.dll=False
Plugintest.dll=False
Webcamera.dll=False
Printer3D.dll=False
UCR200Plugin.dll=False
Xbox360controller.dll=False
Scope.dll=False
AutoLevelerCA.dll=False
HYPLUGIN.dll=True
Modbusmaster.dll=False
UCCNC_OSK.dll=False
XHC-HB04_pendant.dll=False
[Plugins_callstartup]
Debugger.dll=False
Webcamera.dll=False
Printer3D.dll=False
Scope.dll=False
HYPLUGIN.dll=True
UCCNC_OSK.dll=False
[Macroloops]
Macroloopautorun0=False
Macroloopnumber0=0
Macroloopautorun1=False
Macroloopnumber1=0
Macroloopautorun2=False
Macroloopnumber2=0
Macroloopautorun3=False
Macroloopnumber3=0
Macroloopautorun4=False
Macroloopnumber4=0
Macroloopautorun5=False
Macroloopnumber5=0
Macroloopautorun6=False
Macroloopnumber6=0
Macroloopautorun7=False
Macroloopnumber7=0
Macroloopautorun8=False
Macroloopnumber8=0
Macroloopautorun9=False
Macroloopnumber9=0
Macroloopautorun10=False
Macroloopnumber10=0
Macroloopautorun11=False
Macroloopnumber11=0
Macroloopautorun12=False
Macroloopnumber12=0
Macroloopautorun13=False
Macroloopnumber13=0
Macroloopautorun14=False
Macroloopnumber14=0
Macroloopautorun15=False
Macroloopnumber15=0
Macroloopautorun16=False
Macroloopnumber16=0
Macroloopautorun17=False
Macroloopnumber17=0
Macroloopautorun18=False
Macroloopnumber18=0
Macroloopautorun19=False
Macroloopnumber19=0
Macroloopautorun20=False
Macroloopnumber20=0
Macroloopautorun21=False
Macroloopnumber21=0
Macroloopautorun22=False
Macroloopnumber22=0
Macroloopautorun23=False
Macroloopnumber23=0
Macroloopautorun24=False
Macroloopnumber24=0
Macroloopautorun25=False
Macroloopnumber25=0
Macroloopautorun26=False
Macroloopnumber26=0
Macroloopautorun27=False
Macroloopnumber27=0
Macroloopautorun28=False
Macroloopnumber28=0
Macroloopautorun29=False
Macroloopnumber29=0
Macroloopautorun30=False
Macroloopnumber30=0
Macroloopautorun31=False
Macroloopnumber31=0
Macroloopautorun32=False
Macroloopnumber32=0
Macroloopautorun33=False
Macroloopnumber33=0
Macroloopautorun34=False
Macroloopnumber34=0
Macroloopautorun35=False
Macroloopnumber35=0
Macroloopautorun36=False
Macroloopnumber36=0
Macroloopautorun37=False
Macroloopnumber37=0
Macroloopautorun38=False
Macroloopnumber38=0
Macroloopautorun39=False
Macroloopnumber39=0
Macroloopautorun40=False
Macroloopnumber40=0
Macroloopautorun41=False
Macroloopnumber41=0
Macroloopautorun42=False
Macroloopnumber42=0
Macroloopautorun43=False
Macroloopnumber43=0
Macroloopautorun44=False
Macroloopnumber44=0
Macroloopautorun45=False
Macroloopnumber45=0
Macroloopautorun46=False
Macroloopnumber46=0
Macroloopautorun47=False
Macroloopnumber47=0
[SpindlePIDsettings]
PIDenable=False
Kp=1
Kd=0
Ki=0.01
Samplingtime=10
[AUXencodersettings]
AUXencoder1pinA=0
AUXencoder1portA=0
AUXencoder1pinB=0
AUXencoder1portB=0
AUXencoder2pinA=0
AUXencoder2portA=0
AUXencoder2pinB=0
AUXencoder2portB=0
AUXencoder3pinA=0
AUXencoder3portA=0
AUXencoder3pinB=0
AUXencoder3portB=0
AUXencoder4pinA=0
AUXencoder4portA=0
AUXencoder4pinB=0
AUXencoder4portB=0
AUXencoder5pinA=0
AUXencoder5portA=0
AUXencoder5pinB=0
AUXencoder5portB=0
Aux1Encodercountsper=1
Aux2Encodercountsper=1
Aux3Encodercountsper=1
Aux4Encodercountsper=1
Aux5Encodercountsper=1
Aux6Encodercountsper=1
[Digitizesettings]
Addaxisnames=False
Xinclude=True
Yinclude=True
Zinclude=True
Ainclude=False
Binclude=False
Cinclude=False
Commaseparation=False
Filenametosave=C:\UCCNC\Example_codes\Digitize.txt
Numberofdigits=4
Probedia=0
Clearfilenamewhenfinished=False
[UserCheckboxes]
20301=False
20302=False
20303=True
20304=True
20305=True
20306=True
20307=True
20308=True
20312=False
20309=False
20310=False
20311=False
[UserTextfields]
20333=10.000
20334=1.000
20335=3.000
20336=1.000
20337=0.100
20338=0.250
20339=3.000
20340=0.000
20341=0.000
20342=0.000
20343=0.0
20344=0.0
20345=0.0
20346=0.0
20347=0.0
20348=0.0
20349=0.0°
20350=0.0
20304=-0.5
20300=1.101
20301=1.5
20302=1.5
20303=1
20305=0.7500
20306=10
20307=10
20308=-0.5
20309=1
20310=5
20311=10
20312=25
20313=50
20314=100
20315=0.001
20316=0.01
20317=0.10
20318=0.25
20319=0.50
20320=1.00
20321=1
20322=49
20323=-0.5
20324=49
20325=1
20326=-0.5
20327=49
20328=49
20329=-0.5
20330=0.000
20331=0.000
20332=0.000
20351=6.000
20352=0.0500
20353=0.250
20354=10.0
20355=1.0
20356=0.125
20357=0
20358=0.0
[2017JogSpeeds]
913=100
2027=0.01
[Statistics]
TotalM3s=48
TotalM4s=0
TotalM7s=2
TotalM8s=1
Totaltimedays=0
Totaltimehours=2
Totaltimeminutes=30
Totaltimeseconds=48
M3timedays=0
M3timehours=0
M3timeminutes=10
M3timeseconds=45
M4timedays=0
M4timehours=0
M4timeminutes=0
M4timeseconds=0
Cyclestimedays=0
Cyclestimehours=0
Cyclestimeminutes=0
Cyclestimeseconds=40
TotaldistX=374
TotalcutX=4
TotaldistY=306
TotalcutY=3
TotaldistZ=188
TotalcutZ=32
TotaldistA=0
TotalcutA=0
TotaldistB=0
TotalcutB=0
TotaldistC=0
TotalcutC=0
UCdevicetype=UC300ETH_M45
[Hyplugin]
Selectedport=COM10
Selectedbaud=9600
SelectedFreq=400
Selectedminrpm=8000
Selectedmaxrpm=24000
SactField=
AmpFeild=
OnOff=False
AmpCB=False
For whatever reason, there have been several people here with adapters that worked in Mach that do not work consistently in UCCNC. All of their issues went away when they switched adapters.First, let me mention that the hardware (serial adapter, computer, etc) has not changed since I was using this under MACH3. No failures there ever.
Well, I'm using the same one others seem to be using, the JBtek -- anybody have another suggestion?
rick
OK, never mind. I didn't look at the adapter you were using. Same one I am.
Mine is fairly loose in the USB port, and it will lose connection easily if I bump it at all. IS that a possibility?
I use a relay for on/off, though, and have not run into this issue.
Hi Rick,
Your pro file correct settings eliminates all the common problems.
How the plugin works is when UCCNC first starts it sends a command for HZ and won't start working until receives a response from VFD. Even though your using a CH340 RS-485 the fact that it randomly works still makes me think it's a connection issue, if another problem it just won't work. Check your connections like Gerry suggested.
Another sure way to determine if it's a configuration problem or not is to download a free trail Serial Monitor, this will show you what's being sent to Serial Port and know if your problem is before or after serial port. If you need a link let me know.
Another thing to check is make sure your RPM is not lower than your min RPM set in plugin/UCCNC You can set your VFD to display this.
What plugin were you using in Mach3??
If were using Le Royaume plugin check your VFD parameter PD144 and make sure it's on default setting 1440
Here are other settings to check
PD001>>>>>>>>>>>>> 02 Enable commands on port rs485
PD002>>>>>>>>>>>>> 02 Enable speed control on port rs485
PD004 >>>>>>>>>>>>> The Base frequency of your motor (see motor plate)
PD023>>>>>>>>>>>>> 01 Enable reverse rotation (only if you want to run CCW)
PD163>>>>>>>>>>>>> 1 Vfd address
PD164 >>>>>>>>>>>>>1 Line Speed(1 for 9600 bauds) This setting must match with HYPLUGIN
PD165>>>>>>>>>>>>> 3 ( 8N1 RTU)
Dan
Dan,
I made sure of the speed settings, etc.
The converter is located in a place where it won't be bumped or move.
Where can I get "serial monitor" ? I have previously used "portmon" but it doesn't work on 64-bit windows :-(
rick
Dan,
I got a serial monitor running, and captured an example of the system when running and when failing.
It looks like the system is returning very different data for the same commands...
Any ideas?
rick
Code:working not working <. TX> <. TX> #01#03#01#08#F1#8E #01#03#01#08#F1#8E <. RX> <. RX> #01#03#01#00#F0#48 #01#03#01#00#F0#48 <. TX> <. TX> #01#03#01#08#F1#8E #01#03#01#08#F1#8E <. RX> <. RX> #01#03#01#00#F0#48 #01#03#01#00#F0#48 <. TX> <. TX> #01#03#01#01#31#88 #01#03#01#01#31#88 <. RX> <. RX> #01#03#01#00#F0#48 #01#03#01#00#F0#48 <. TX> <. TX> #01#03#01#01#31#88#01#03#01#01#31#88 #01#03#01#01#31#88#01#03#01#01#31#88 <. RX> <. RX> #01#03#01#09#30#4E #01#03#01#01#31#88 <. TX> <. TX> #01#03#01#01#31#88 #01#03#01#01#31#88 <. RX> <. RX> #01#03#01#09#30#4E #01#03#01#01#31#88 <. TX> <. TX> #01#03#01#01#31#88 #01#03#01#01#31#88 <. RX> <. RX> #01#03#01#09#30#4E #01#03#01#01#31#88 <. TX> <. TX> #01#03#01#01#31#88 #01#03#01#08#F1#8E <. RX> <. RX> #01#03#01#09#30#4E #01#03#01#01#31#88 <. TX> <. TX> #01#03#01#01#31#88 #01#03#01#08#F1#8E#01#03#01#08#F1#8E <. RX> <. RX> #01#03#01#09#30#4E #01#03#01#00#F0#48 <. TX> <. TX> #01#03#01#08#F1#8E #01#03#01#08#F1#8E <. RX> <. RX> #01#03#01#09#30#4E #01#03#01#00#F0#48 <. TX> <. TX> #01#03#01#08#F1#8E#01#03#01#08#F1#8E #01#03#01#08#F1#8E <. RX> <. RX> #01#03#01#08#F1#8E #01#03#01#00#F0#48 <. TX> <. TX> #01#03#01#08#F1#8E #01#03#01#08#F1#8E
