586,075 active members*
3,982 visitors online*
IndustryArena Forum > CNC Electronics > Xylotex > Can I hook up a 3-axis board to a 1-axis board ?
Results 1 to 8 of 8
    Oct 2004
    85
    I allready have my Xylotex 3-axis system up and running.It works great! Now I would like to put another motor on my X-axis.What I need to do is slave them together,but I will need another drive for the A-axis (slave axis for the X).Is it possible to hook up a single axis drive to a 3-axis drive.This would make it 4-Axis.If so, How should I go about this?
    Thanks Jim
    Aug 2004
    3215
    Quote Originally Posted by Redline View Post
    Thanks Jim
    you will need another axis driver seperate from the "X" brand. look and see if it has pinouts for 8 and 9 pins if so then you can hook step and direction to those, is not then you will need to use a pass through "B.O.B." card, or another printer port and configure the 4th axis to lpt2 and then in your software, (i.e. Mach3) to slave the axis.
    Joe
    Oct 2004
    85
    When you say
    Quote Originally Posted by joe2000che View Post
    Does that mean I cannot use the Xylotex single axis board? What board should or could I use. Send me a PM it you don't want to say it here.
    Aug 2004
    3215
    When you say
    I would send them a message and ask how to install it in conjunction with their 3-axis board, I guess that is what you are trying to do.
    Joe
    Oct 2004
    85
    Yes that is what I would like to do,but Jeff is slow to respond.
    Mar 2006
    759
    You can modify your DB25 cable, which is messy and a pain,
    get a nice breakout board, and spend quite a bit of money
    or get a smaller breakout board like this
    http://cgi.ebay.com/CNC-DB25-BREAKOU...QQcmdZViewItem
    "If the women don't find you handsome, they should at least find you handy"
    -RedGreen show.
    Looking at the datasheet, you can get the 5V, ground, and A axis step and direction from the small red connector on the front right side of the 3 axis board. Just run those 4 wires to the single axis board. I have an older single axis board that plugs directly into my older 3 axis board.
    Oct 2004
    85
    That was the answer I was looking for ,Thanks
  1. 2 axis board assembly
    By JamesJmcGEE in forum Hobbycnc (Products)
    Last Post: 10-24-2006, 06:04 PM
  2. how to hook breakout board to geckos?
    By Apples in forum Gecko Drives
    Last Post: 09-06-2005, 01:05 PM
  3. 3 axis board
    By extreme in forum Open Source Controller Boards
    Last Post: 06-12-2005, 10:08 PM
  4. 4th axis controller board?
    By cncadmin in forum DeskCNC Controller Board
    Last Post: 08-30-2004, 09:38 PM
  5. board hook-ups
    By landart in forum DIY CNC Router Table Machines
    Last Post: 11-29-2003, 04:49 PM
