586,449 active members*
3,208 visitors online*
IndustryArena Forum > CAM Software > Uncategorised CAM Discussion > Galaand/Kay software for Isel/Unimatic
Results 1 to 11 of 11
    Apr 2012
    91
    If anyone is using an old Isel router? I would welcome an opinion on the Kay software used for feeding Isel control boxes with remote code. Can it be used independently of the Galaad software for instance. Indeed if you are using an original Isel box I would be most grateful for your communication, as I would to fit some addons. Tool Z height pads etc. Thanks in advance.
    Jan 2014
    37
    Re: Galaand/Kay software for Isel/Unimatic
    Quote Originally Posted by Eatonbrayer View Post
    Yes it can be used independently and it is sold seperatly.
    Apr 2012
    91
    Dune - Thank you for reply. Just finished hooking up the demo version and it runs and homes the machine perfectly.
    Have you any knowledge about configuring the inputs and outputs on the back of the cabinet please?
    Mar 2016
    325
    Which input You want to configure?
    Back there as i recall there are only 3 or 4 inputs. You configure them in "Machine" menu. in last page.unfortunatelly there is not to many functions that You can set.
    Apr 2012
    91
    Steryd - Apologies for not having investigated the Machine menu intelligently.
    There are two output banks. One with 0 to 8 terminals and one with a 9 pin RS232. One input bank with 0 to 8 terminals.
    I would like fit a Z axis tool sensor initially. Would be grateful if you have any guidance for setting this up.
    Mar 2016
    325
    Try to mark that Your machine is equipped with tool length sensor, then there 'll be defoult port number asigned. It'll be one of free inputs on the back connector and You can find it in manual or check it by connecting pins to .
    When You connectYour tool probe You need to calibrate it before use.
    Apr 2012
    91
    Steryd - The machine did not come with a tool sensor. I will have to make one. Either a simple flat plate, tri-corner plate or spring plunger. The Kay software has full provision for a Z tool sensor, but no reference to the port number. The software "seems" a bit vague in this respect. But I am unfamiliar with it. - Hoping to discover otherwise as I gather more knowledge.
    Mar 2016
    325
    I'm not sure, but when i turn the mark on toolsensor option there already was asigned port number (yes i did install galaad from scratch).
    Try to find manual for the controller. There should be informations about inputs location. And then You can connect Your sensor to machine.
    Apr 2012
    91
    Steryd - Do you ground the toolbit before contacting the tool plate please.
    Mar 2016
    325
    No. I have a sensor that uses simple limit switch and it's cover is grounded.
    Apr 2012
    91
    Steryd/Dune1982 - Just a line to thank you for your help. All up and running with new Kay licence and F360 3d files. Performing excellently so far. All original equipment.
    Regards
    EatonBrayer
  1. Please somebody to help ISEL C142-4 to mach3 control software how
    By Sasa90 in forum Machinery Manuals / Brochures
    Last Post: 08-14-2016, 09:13 PM
  2. Isel EP1090 Software
    By MisCar in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 11-27-2015, 03:40 PM
  3. Techno Isel Software
    By johnono in forum Commercial CNC Wood Routers
    Last Post: 08-02-2010, 02:31 AM
  4. Techno-ISEL MAC 100 software?
    By wmb in forum MetalWork Discussion
    Last Post: 08-09-2006, 09:39 AM
  5. HELP!! Software for Isel EP-1090
    By Riffraff2 in forum Benchtop Machines
    Last Post: 11-18-2005, 06:22 PM
