Originally Posted by
energytek
So, I got the new powermax 45 xp machine torch setup for my diy 4x4 table. I started off with the standard nozzle working with
mild steel .125 and ,060 . floating head only . set to cut chart and all is well. The problem comes when I got the fine cut parts and
set the parameters in sheet cam from the cut chart. made the cut file and run it . more often then not m03 will light the torch and
start to move and arc will go out and it will continue to run and not cut till the next m03 and the same repeats. while I have completed
a run with these nozzles, it is rare. I do not have any issue with standard nozzles. I did read in a forum about revised cut speeds for
the fine cut to 150 ipm . Jim Colt? and still the same issue. What cuts i do get are great. no slag at all, when it cuts. revert to std. nozzle
reset cut file to cut chart settings it is back to a good cut with some slag . I sent a inquiry to hypertherm through their site and no response.
