586,103 active members*
3,222 visitors online*
    Oct 2006
    157
    Puma 10 Turret problem
    Hello,
    I bought this used Puma 10 .
    After purchase I found out it had been crashed.
    I am now trying to get the turret apart to pull the tapered pins and get it squared back up.
    The plate in the pic with the numbers on it I need to pull off.
    The pin that went thru this plate and the shaft has been bent and is kinda thu the plate and shaft at a zig zag angle ( du to the shaft sating put and the plate moving)
    I have ground / drilled the pin down thru the plate to the shaft.
    Any idea the best way to pull the plate off of the shaft ???
    Thanks!
    Oct 2006
    157
    Re: Puma 10 Turret problem
    Nobody ever had one of these apart?
    Oct 2006
    157
    I am still searching for any input .
  1. Aligning turret on a Daewoo Puma 10, 12 tool turret
    By AirChunk in forum Daewoo/Doosan
    Last Post: 06-03-2016, 02:37 AM
  2. Puma 300 turret noise
    By roacher88 in forum Daewoo/Doosan
    Last Post: 10-27-2015, 09:24 PM
  3. puma 250 turret is getting very warm
    By BJ100 in forum Daewoo/Doosan
    Last Post: 11-11-2014, 06:08 PM
  4. Turret trouble Puma 10S
    By Kenneth434 in forum Daewoo/Doosan
    Last Post: 08-14-2014, 10:05 PM
  5. puma 6-3a turret positioning
    By wbmach in forum Daewoo/Doosan
    Last Post: 04-13-2008, 05:06 PM
