I'm currently in the design phase of my CNC and its loosely based on the Momus design as I really like the sunken bed. I'll be drafting the design using AutoCad and the slowly purchase/build it over the course of a year or so.
I hope to have a cutting area around 4' x 4' X/Y and a 1' Z using Linear Rails/Ball screws.
Attached is the first draft of the frame which is made from various grades of T Slot (90mm x 90mm, 90mm x 45mm and 45mm x 45mm) and the frame size is 7' x 7' x 2' (with a 1' sunken bed). Keep in mind this is a first draft and will more than likely change.
