586,075 active members*
3,967 visitors online*
IndustryArena Forum > MetalWorking Machines > Bridgeport Machines > Bridgeport / Hardinge Mills > hardinge VMC600 programming issue when using R-word insert arc
    Nov 2012
    68
    I had a strange issue with a simple program at work on our VMC 600. I need to cut a 1/2 radius in a steel channel where 2 intersecting points meet. Instead of using a 1" endmill I'm using a 1/2" and want to just generate the arc with the R-word method. For some reason the machine cut a 3/4" radius instead, what gives?
    Here is an example of my program:
    X-16.0 Y-2.0
    X-12.0 R .5
    Y-4.0
    No cutter comp. used.
    Any suggestions?
    Feb 2007
    314
    Re: hardinge VMC600 programming issue when using R-word insert arc
    the answer is in the question: No cutter comp. So the center of a 1/2" endmill follow a path with a .5" radius. 1/4" radius of tool +1/2" toolpath radius= 3/4"
  1. Replies: 0
    Last Post: 01-07-2012, 04:17 PM
  2. Bridgeport VMC600/22
    By de_firma in forum Bridgeport / Hardinge Mills
    Last Post: 12-18-2011, 11:50 AM
  3. Need help programming Hardinge T65
    By dfrey2@rocheste in forum Hardinge Lathes
    Last Post: 11-02-2010, 10:15 PM
  4. hardinge contract programming
    By woodywoodward in forum Hardinge Lathes
    Last Post: 12-09-2009, 10:11 PM
