Well I think I'm about to throw in the towel on my pulley system and go with straight lovejoy type couplers.
I get tons of noise when the belts are tight enough for minimal backlash, and way to loose to quiet them up. Alignment is pretty tricky too.
I can't remember the type off the top of my head but they are a 15mm wide belt, 5mm pitch (90percent sure without looking) trapezoidal type designed for precise motion and power trans.
So I've been thinking about the lovejoy L075 or L095 hubs. The 19mm motor end has a 6mm keyway which I can find everywhere for a good price.. the ball screw end though I'm concerned with
Its a 15mm shaft end with no keyway etc. Looking at the lovejoy hubs I see they just have the 2 set screws. Other Chinese couplers have a clamping style.
So my question. With 750w ac servos, am I going to be OK with lovejoy set screws, or do I need to look into bushings etc.
My other question is my motors are rated for 3000 rpm and my balls crews probably won't handle much more than say 1500 to 1800 rpm. Currently I'm using a 2 to 1 belt system for this. Am I going to have any issues running motors at half rpm?
Sent from my SM-N910V using Tapatalk
