586,058 active members*
4,290 visitors online*
    Nov 2016
    setting limits
    Hi I'm a newbie to cncs, When I set my limits to X0 & Y0 bottom left, and set z to top of material, my cnc thinks it's top right, I've tried everything I can find on youtube etc but it always thinks the left is right, I hope some one can explain in straight forward English, thanks eveyone ( Keith ).
    Re: setting limits
    Sounds like your machine is setup backwards.
    Feb 2009
    192
    Re: setting limits
    A simple test to verify that the machine will move in the appropriate direction would be to manually jog the machine. If you jog the machine to the left and it moves to the right your directional signals to the motors are reversed. Test all '3' axis to verify that they move correctly. If you find that the machine does indeed move opposite to the intended direction it's a simple software fix in your setup menu.
    If you are using Mach3 motor direction can be changed withing the 'Homing/Soft Limits' screen.
  1. Setting up Config >Homing/Limits Dialog (Motor Home/Soft Limits)
    By CStevens6 in forum Mach Software (ArtSoft software)
    Last Post: 07-18-2013, 04:19 AM
  2. Need help with setting up home/limits PLEASE!!!
    By Eddieman in forum Mach Software (ArtSoft software)
    Last Post: 10-24-2011, 04:58 PM
  3. Setting limits on a demo version
    By UCF_Prince in forum Benchtop Machines
    Last Post: 03-15-2011, 05:35 PM
  4. help setting up limits
    By mike944 in forum Mach Software (ArtSoft software)
    Last Post: 06-01-2009, 02:07 PM
  5. Setting Software limits
    By bherr in forum Bridgeport / Hardinge Mills
    Last Post: 04-06-2009, 05:31 AM
