586,119 active members*
3,605 visitors online*
Results 1 to 7 of 7
    Nov 2014
    6
    Exclamation i don' know what is this problem !!
    hi , how are you ? i'm happy to right this message on your forum .
    please can you help me whit this problem :
    i dont know what is the proble whit the cnc i give it the work on right and it do the left work !!!
    please i need your help
    thank you .
    Nov 2014
    6
    Re: i don' know what is this problem !!
    please someone help me
    Dec 2008
    3109
    What type of CNC ? laser, wirecut, mill etc ?
    if milling.... guessing at possible leadscrew play...ie leadscrew nut, thrust bearing, joint with axis drive motor
    ( if your arrow is pointing in the X- direction.......the Y axis is what could be the problem )
    Push / pull the table ( use a dial indicator ) to see if you have movement
    15362
    fouzdo9
    Post your program
    Mactec54
    Nov 2014
    6
    Quote Originally Posted by Superman View Post
    thank you i will tray
    Nov 2014
    6
    fouzdo9
    Post your program
    thank you
    actually i have the problem on mach3 and nc studio .
    Jun 2010
    4256
    Looks as though you may have your X axis Dir signal 'upside down'. Go into Ports&Pins and reverse the active state for that pin.
    Cheers
    Roger
  1. Fadal Idler problem. Rpm pulse problem
    By complextool in forum Fadal
    Last Post: 10-07-2016, 06:28 PM
  2. Tube problem or powersupply problem? Help you to check out
    By Melody-gweike in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 10-05-2012, 04:09 AM
  3. daewoo puma 12lb tape format problem/parameter problem
    By robb12877 in forum Daewoo/Doosan
    Last Post: 08-25-2011, 06:13 AM
  4. Replies: 5
    Last Post: 08-04-2010, 11:33 PM
  5. machine problem or software problem?
    By bcnc in forum Syil Products
    Last Post: 10-26-2009, 03:51 PM
