Hello all. Small problem here, and was hoping someone could point me in the right direction. I'm using AlphaCam Essential 2016 R2. When I use the simulator and show the toolholder, the toolholder is absolutely huge...looks to be about 5' in diameter. This is really just an annoyance, as it has no bearing on the operation of the machine, but I would like to know if there is a system parameter somewhere that I am missing. I set it as an HSK63F with 462E collet from the programs' library. Has anybody else had an issue with this, or know of a parameter or system setting I should check? Thanks much for the help!
