First off, as this is my first post, I wanted to start by thanking all of you. I have been on here for a while, reading and learning. The information here is invaluable. What a great thing you have all created, and I thank you for that. Following my dreams would otherwise not be possible. This is my first machine, and I have never machined anything in my life. So, I guess I am also a bit paranoid.
I picked up this machine and shorty noticed that the way lube pump was only showing about 2.5 kg/cm2. I opened the manual, and it lists output pressure as 16kg/cm2. After searching, 16 seems to be around the norm. I pulled the filter and cleaned it, as well as pulled the pump out of the reservoir and cleaned the pickup and sludge from the bottom as well. Everything was very plugged. After this, pump pressure came up to 7kg/cm2. When the pump shuts off this immediately drops to about .5-1kg/cm2, and stays for about 30 seconds before dropping to zero. The vertical Z ways get a lot of oil. The left way (first one fed) on Y gets plenty of oil. The right way on Y, and the table (as best as I can tell) are not getting any oil at all. I have opened up several of the metering jets (or whatever you want to call them) and none are plugged - but also, this should cause increased pressure anyways, right ?
I pulled the main line coming into the manifold for the X (table) and had a friend hold the instant switch. All I get is a drip every 5 seconds, almost no flow at all. I can't find the manifold / junction before this (fear I would have to take the table off). I am hoping this is only because I am not getting enough pressure...
I cannot find any leaks. I have looked and looked. I have also gone through a good quart of oil in the process, and the only oil I can find are on the ways. I strongly feel there are no leaks. I have traced every line from the pump to the way as best as I can, although some areas are nearly impossible to get to, but I have found no leaks.
There is 1 line to a manifold for Z and 1 line to a manifold for X / Y. I plugged the Z line and got about 10kg/cm2. I then plugged the line directly after the pressure gauge, and still only got around 12kg/cm2. This told me that either the pump was bad, the motor was weak, or the pressure regulating device was not adjusted correctly (assuming I am supposed to see 16kg/cm2)
I bought a new pump assembly off EBay for $275. Replacing the whole thing was a bit of work so I only replaced the motor and pump and placed this inside my existing reservoir. Plus, mine was already all nice and clean. Here is where I noticed something strange. The new pump was wired as follows: Black to black, white to white, red to red, and ground. My old pump was wired.... Black to red, red to black, and white to white. The DIP switches had also been adjusted inside the controller, so someone had been here before. I wired in the new motor the same as it came, colors matching to each color. Turned it on, and it ran backwards. I then checked every connection back to the main cabinet and confirmed that all U / V / W lines were going to the corresponding U / V / W, nothing was flipped. Odd. I switched the black and red wires, and it runs forward, but pressure is still the exact same.
Sorry for such a long post, but I guess these are ultimately my questions:
1. What pressure should I be reading when the pump is running?
2. I think the pump phase sequence may be what is wrong. I don't know much about this, but is there a way for me to tell without spending more money on a $100 tool that I may not need?
3. If pressure is low as I suspect, and phase sequence checks out as good... what else could be wrong? Why am I not getting enough pressure? Line to line voltage at the pump is 208 on all lines.
Thank you very much... I want to run this thing so bad!! And don't want to waste any more money on parts I don't need.
