586,121 active members*
3,701 visitors online*
IndustryArena Forum > CAM Software > Visual Mill > Reverse thinking on a 4th axis
    Aug 2003
    318
    Question about VM5 and a 4th axis. I want to put a 4th axis rotary on my router but the gantry height is only 7". Can I rotate my router 90 deg and use the Y axis as the Z and use my A axis for the rotary.
    Am I seeing this correct? In a normal setup If the part is rotating then the Y axis would stay put the Z would move up and down and the X would go back and forth. Would the Y need to move or would the fact that it rotates alow the bit to get to all parts.
    Donny
    Jan 2004
    490
    I don't see why not. Horizontal milling machines are oriented in this way. Wiring may have to be reversed in actual use though (unless your software can do it) to switch the X and Z, as the X will now be the axis moving the cutter to the work.
    Stop talking about it and do it already!!!!!
  1. 4th Axis Parallel Roughing
    By whiteriver in forum Visual Mill
    Last Post: 06-17-2007, 05:10 AM
  2. 4020 4th axis problems
    By little bubba in forum Fadal
    Last Post: 06-14-2005, 03:08 AM
  3. 4th axis tutorial?
    By Monte in forum BobCad-Cam
    Last Post: 05-20-2005, 03:07 AM
  4. 4th Axis
    By UKRobotics in forum Uncategorised MetalWorking Machines
    Last Post: 03-19-2005, 04:25 PM
  5. Can 4th axis do offaxis undercuts ?
    By lesd in forum Visual Mill
    Last Post: 12-17-2004, 01:27 PM
