586,096 active members*
3,772 visitors online*
Results 1 to 10 of 10
    Mar 2014
    7
    20W Fiber Laser!
    I bought a 20W Fiber Laser and I didn't get all the info to the machin how I should do when I install the machine...
    I bought this one Newest 20W Desktop Potable Mini Fiber Laser Making Machine Engraver / Maker | eBay
    Can someone please help me..
    How do I connect the machine with my PC? USB LAN Or how?
    Thanks!!
    Tom
    Mar 2009
    533
    Re: 20W Fiber Laser!
    According to your link, USB.
    You didn't get a user manual with it?
    Jun 2005
    1730
    YUP, the specs printed below the ebay ad show this connects to the USB port. No manual unreal.
    Russ
    Mar 2014
    7
    Manual only in Chinese... and no software where I could use the Laser.. Is it just to connect to a computer and print or how do I do it? I have a 40W co2 laser and it came a software with it and I opened the software and added just the co2 lasers number and it works well...
    Jun 2005
    1730
    The ebay ad says it comes with the Marking Software, it also says you only need a monitor, keyboard, and mouse to start using. Is there maybe a built in computer unit on the square box? A vga monitor plug maybe?
    Russ
    1.20W Q-Switch laser source.
    2.Power supply.
    3.Galvo head.
    4.Theta lens.
    5.Marking software.
    You need to prepare keyboard, mouse and monitor,then you can begin to work with the device
    Jun 2005
    1730
    Look up on youtube they have some of these units working. Looks like there is software for them, I would contact the seller they will probably send you a link to download the software.
    https://www.youtube.com/watch?v=tnzDShQzwwE
    Mar 2009
    533
    Generally you need a computer connection, which in your case is a USB port.
    Then you need software, installed on your computer, which understands the laser commands.
    Your system appears to "rasterize" the artwork and sends laser commands to turn the laser off or on and control for the X & Y co-ordinates based on picture data.
    Without the proper software I don't see how you can make it work. You should ask the seller about this issue.
    Mar 2014
    7
    This what it is on the laser Box... So I don't know where to put the keyboard mouse and monitor...Click image for larger version.
    Mar 2009
    533
    The keyboard and mouse connect to a computer, not the laser unit.
    This video shows a similar unit and it uses a computer built in a monitor.
    It also appears to use the LAN from the laser unit to the computer, around the 5:38-5:40 time mark
    https://www.youtube.com/watch?v=_1lEiiBWC_I
    Mar 2014
    7
    OKAY, So it most be that I don't have the Max Marking 2 software and that's why the laser dosen't resdond to anythind, dosen't give me a red dott or nothing...
  1. Replies: 0
    Last Post: 03-28-2016, 05:39 AM
  2. AK10F- A Portable Fiber Laser Marking Machine for Plastic, Fiber and Metal Engineerin
    By aaronhernandez in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 01-29-2016, 05:35 PM
  3. Metal Fiber Laser marking sample by consure laser
    By consurelasercnc in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 11-05-2015, 09:55 AM
