586,072 active members*
4,451 visitors online*
    Jul 2009
    5
    Backlash free gear?
    I'm taking apart my Nakamura Tome TMC-3 to retrofit and pretty much look over every component of the machine. I took off the Z servo and found this:
    nakamura - z servo - Album on Imgur
    I see straight cut gear teeth. I'm confused on how they're eliminating/minizming backlash. I was thinking there would be some sort of harmonic drive, but to my surprise it's just gears. Any ideas?
    May 2013
    480
    Re: Backlash free gear?
    You can actually preload the gears and achieve zero backlash, however you must have properly engineered lubrication otherwise the gears will wear. basically the oil film thickness and preload needs to be just right, so that during operation the oil film and the applied torque pushes the gears away from each other so they don't contact each other.
  1. Zero backlash worm gear idea.
    By ynneb in forum Mechanical Calculations/Engineering Design
    Last Post: 06-28-2014, 04:20 AM
  2. Backlash free R&P
    By Al_The_Man in forum Linear and Rotary Motion
    Last Post: 03-07-2014, 06:28 PM
  3. what is consider low backlash for gear box?
    By eloid in forum DIY CNC Router Table Machines
    Last Post: 04-22-2009, 11:28 PM
  4. Wacko gear backlash (or not)????
    By IQChallenged in forum Uncategorised CAM Discussion
    Last Post: 02-01-2008, 03:00 AM
  5. gear backlash
    By phil spanner in forum Mechanical Calculations/Engineering Design
    Last Post: 09-08-2005, 02:38 PM
