586,068 active members*
3,739 visitors online*
IndustryArena Forum > CAD Software > Rhino 3D > Boolean operation on STL files
    Feb 2007
    413
    Hello,
    Can you tell me if this is possible please.
    I have a STL file of a part that I need to make a mould from.
    I imported the STL file and then created a cube that is big enough to cover half the model.
    When I try to do a Boolean operation, it won't select the STL object.
    Any help appreciated.
    Thank you.
    Mar 2006
    81
    Re: Boolean operation on STL files
    In order to do boolean operations on STL files, you have to convert your other object into a Mesh, as STL files are imported as meshes, not as NURBS surfaces/solids.
    So, in order to do this, take your created cube, go to the upper menu and go to the MESH tab, and choose MESH->From NURBS object. then select your box/cube.
    Now you have a cube mesh.
    Now you can do Mesh Boolean Operations such as Union/Intersection/Difference, by going to the MESH tab and selecting MESH Boolean.
    That should take care of it.
  1. Boolean Subtract WTH
    By jrmach in forum BobCad-Cam
    Last Post: 10-10-2014, 01:32 AM
  2. Tool plunging at beginning of operation + lost files.
    By JackWilliam in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 05-17-2013, 03:29 PM
  3. Boolean Operation with a Mesh
    By chaddcurtis in forum Rhino 3D
    Last Post: 02-22-2011, 09:08 PM
  4. V22 Boolean Subtract
    By TZ250 in forum BobCad-Cam
    Last Post: 12-03-2008, 08:11 AM
  5. Boolean
    By camtd in forum Uncategorised CAD Discussion
    Last Post: 09-22-2008, 12:31 AM
