586,106 active members*
3,077 visitors online*
IndustryArena Forum > MetalWorking Machines > Tree > Tree 2UV quill extremely tight and shaft damaged
    Jan 2015
    35
    I just picked up a tree 2UV mill and have begun fixing a few small things that I've noticed. The current situation is that even with the spindle lock off, it is very difficult to raise and lower the spindle. Not smooth and easy like it should be. I also found that several of the splines on the shaft that raise and lower the spindle were sheared off. How does the spindle get removed so I can further inspect and clean? Also, the machine came without the yoke for the collet closer. Are those available anywhere?
    Jan 2016
    99
    Re: Tree 2UV quill extremely tight and shaft damaged
    If this is a manual machine(some of the cnc have the same head) the quill comes out the top.
    The motor has to come off. What drives the spindle on mine is a coupling with rollers and eccentric pins to snug up vs a spline on a Bridgeport
    Problem is the rollers wear a divot from driving at the same speed.
    An upgrade was flat pucks that still used the eccentric pins. I made my own and it works but it's a very well worn machine. It is a real pain to reassemble with the puck though. They get adjusted through a pipe plug on the front.
    There is also a key that is screwed to the quill that works with the depth stop.
    Dave
  1. Delrin Nut Extremely Tight
    By Barefooter in forum DIY CNC Router Table Machines
    Last Post: 02-12-2012, 05:06 PM
  2. Problem with tight quill movement
    By laser3kw in forum Bridgeport / Hardinge Mills
    Last Post: 01-27-2011, 01:14 AM
  3. Bridgeport Series I 2J quill too tight on reassembly
    By supahonkey in forum Bridgeport / Hardinge Mills
    Last Post: 01-21-2011, 04:12 AM
  4. tree power quill feed
    By ahrmaracer in forum Tree
    Last Post: 03-01-2008, 03:16 PM
