Originally Posted by
CJL5585
What you DO want is the LOGIC supply (5V) for the Gecko's, the breakout board, and the computer parallel port to have the same common. This is accomplished by connecting the 5v common (sometimes called ground) to the common pins on the breakout board which automatically are connected to the computer logic supply common inside the computer when the breakout board is connected via the DB-25 cable.
The only COMMON GROUND that you need in a system is the EARTH or utility system ground from the power company. It attaches to the equipment enclosure(s) which contains the CNC components. This Earth ground should not be attached to any power supply outputs. It goes only to the input voltage side of transformers and other equipment designed to be connected to the earth ground. If in doubt, read the NEC Codebook, insurance company regulations, the National firecode, and attend a seminar or two on proper grounding techniques for electronic equipment.
This can be misleading, as there is also a common practice to ground all power supply commons to a ground plate set up in the enclosure which is connected to the incoming service ground conductor, including the PC supply common and all shields, this is something I have practiced for many years and have never had a problem, this includes many PC based systems, using servo's and other equipment.
This method relies on having the lowest resistance path possible to earth ground for all of these components.
Ref: NFPA Electrical Standard for Industrial Machinery.
'Control Circuits shall be permitted to be grounded or un-grounded'.
In any event, you should follow the recomendations by Gecko as the above preferences are my own.
Al.
Albert E.
