586,781 active members*
3,124 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > Any swedish MX-45 machine users out there?
Page 1 of 2 12
Results 1 to 20 of 23
    Jun 2008
    113
    Which of the following button is DRY RUN??
    Thanks!
    Jun 2015
    4156
    Re: Any swedish MX-45 machine users out there?
    hello, don't u have a "IL" button, or something ( white) , that you can press in combination with the buttons that you don't know what they do ? maybe you will find it maybe it will light up
    also, why do you need dry run ? collision check, program check, 4 what ? kindly !
    Dec 2008
    3113
    Not overly clear,, but this link.....LINK .... go to page 516
    I assume it is a OSP 7000M control
    Jun 2015
    4156
    did u just replied without messing my head ? but i am used with that since my 1st post on cnc zone ... pls
    Jan 2010
    171
    Not easy to read when your buttons is so dirty but i believe it says "TORRKÔRN"
    Dec 2008
    3113
    Quote Originally Posted by deadlykitten View Post
    WTF are you getting at ?
    What business is it to you why he needs to know, .... probably to prove off a program at a faster speed, like most normal people
    myhaje
    -- tell us what control it is hiding under the dirt
    .....clean your operation panel.....turn the machine OFF, & clean using a soft cloth dipped in your cutting fluid or a dishwashing liquid
    Jun 2015
    4156
    finally
    WTF are you getting at ? What business is it to you why he needs to know
    i can sugest how 2 check colisions without cas, thus reducing general time setup
    a lot of people complain about duration of setup, because of the need to declare everything also virtual
    nothing new here, just techniques before cas ... cas is safer, is good to be there, but is good to dont regard it as a must
    also try spirit / alcohol and cotton buds for details
    Sep 2008
    138
    Hi
    May be it the same with your operator panel
    Quote Originally Posted by myhäje View Post
    Thanks!
    Jun 2015
    4156
    hey myhaje, instead of cleaning, just stick this to it
    Jun 2008
    113
    TORRKÖRN it was. I use dry run to cut air faster where material was already taken out and the program has to be re-run.
    Jun 2015
    4156
    TORRKÖRN it was
    ... and still is
    why don't u just use restart ? or you must continue from the middle of a long operation / cycle ? in that case, you may use parametric programs ... however, you should reduce / eliminate such unnecesary movements by programing ; kindly !
    Jun 2008
    113
    Well, I try my best, but still sometimes inserts refuse to last until the end. Instead of starting to mess with the program, it's just faster to re-run that phase with dry run on to the point where it starts to take material.
    Jun 2015
    4156
    hello again generally, is faster to go dry than to reload the program
    fast insert wear, especially when cutting single parts, is a mess i would recomend some better inserts; this is all i can tell
    i experienced with different setups and different inserts from dealers, and in the end i found something better; i have done this because my inserts did not last long
    so far i had problems only when roughing; inserts that i have now are ok for roughing, actually so ok, that they push the material if is not clamped well, so this is why i started crafting hard jaws
    another issue is the spindle speed; i don't go over 2000rpm on the 10"chuck, even if the insert can take it ... i don't like how the machine behaves at this speeds, so i preffer to protect the spindle / kindly !
    ps : i can hit 2000rpm 0.7mm/o 1mm depth on diameter 65, and i feel that the spindle can take much more, but the Z axis is loaded ... is like how the S motor is much powerful than the Z
    Dec 2008
    3113
    Err..... it's a milling machine you dill...not a bloody lathe
    Jun 2015
    4156
    yeah, u r right i should have figure it out from the panel that i photoshoped
    Jun 2015
    4156
    on a lathe there are potentiometers / fine adjustment control for rpm and feed
    on a mill there are or :
    ... rpm
    ... rapid
    ... feed
    ... feed in MDI, or during restart; also this last one allows machining in MDI pretty precise, like you can set up exactly whatever feed you need
    so, on a mill :
    ... rapid adjustment is independent from feed adjusment, while on lathe they are combined; same button/wheel for bought
    ... you can machine inside MDI at a specific feed only from the panel, which is faster; on a lathe this can not be done
    again, team vs team
    so maybe i should have figure it out that the MX-45 is a mill, but what is the "manual cutting feed" option for lathe ?
    Jun 2015
    4156
    i think there may be a way for an inside cycle restart, without program optimization / i will be back on this
    Jun 2015
    4156
    pls check attached image that highlighted value, during machining, it counts internal operations, without connection to the N**** address
    thus, when an insert goes, just remember than number, which is a link for the current operation
    reset, change insert, and restart the program with a value lower than the one where your insert got screwed
    generally, try restarting on a line where the tool is out of the material, or is about to enter ( preferably tangent ) inside the material
    this is 4 osp 300 ; hope it retrofits
    same for lathe : i had an operation which starts with the tailstock active, and during it the tailstock leaves; there is no chance to restart inside this *.ssb by using normal methods, unless :
    ... each line has an N**** address, which i don't use pretty often, or
    ... direct restart is used, but still not possible, because you can not select a line inside the *.ssb / kindly !
    Jun 2015
    4156
    if you skiped that link, thus the insert got broken and the cnc continued, just stop & reset, and run the program in virtual mode so to see the link where the insert broked
    if it takes too much, enter the program and put an M0 somewhere, and after run in virtual + dry; simulation will stop at M0; check the link and restart
    well, also, you may input, instead of M0, an N**** adress, and restart directly on it, as long as that adress is unique ( preferably )
    Jun 2015
    4156
    things lately described, as restarting at internal cnc address (=ica) instead of N****, do not work if you loop a program inside a *.min, because the ica will not reset when it will meet the GOTO syntax
    so better just input an N**** somewhere, and restart on it, or enable the ica reset and keep the looping by using *.sdf
    in this last case, spindle and everything will stop, since the *.sdf chaines programs, not simple operations; no worries on a mill, while on a lathe you may have issues with this on a material advancing without spindle stop this just hit me a few seconds ago ...
Page 1 of 2 12
  1. Swedish build 2x1.7 meter CNC plasma table
    By Diman in forum Plasma, EDM / Other similar machine Project Log
    Last Post: 11-08-2013, 05:30 PM
  2. Language problem Swedish to English
    By Klasu in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 03-25-2010, 03:57 AM
  3. Swedish Lidkoping turret lathe rebuild
    By WillyK in forum Vertical Mill, Lathe Project Log
    Last Post: 02-06-2009, 03:46 PM
  4. Swedish router, first try...
    By sweFredrik in forum CNC Wood Router Project Log
    Last Post: 04-20-2008, 11:48 PM
  5. Questions from a swedish newbie!
    By Bosen in forum Stepper Motors / Drives
    Last Post: 03-12-2006, 11:15 PM
