586,060 active members*
3,888 visitors online*
IndustryArena Forum > WoodWorking Machines > Commercial CNC Wood Routers > Chinese Machines > HY 6040 cnc router any comments, someone have it?
Page 2 of 2 12
Results 21 to 27 of 27
  1. #21
    Dec 2019
    27
    Re: HY 6040 cnc router any comments, someone have it?
    Quote Originally Posted by HamHamid View Post
    Good Job !
    Have you succeed to mill with the 5 axis, and what the post processor that's you used ?
    I did not try yet with material, but I was moving the axis with no material and it seems to work. I used a modified Mach3 post processor.
    Inviato dal mio iPhone utilizzando Tapatalk
  2. #22
    Dec 2019
    27
    I cut aluminium without any problem and with good accuracy.
  3. #23
    Dec 2019
    27
    Quote Originally Posted by hlopezho View Post
    Hi all..just passing bu to update on my progress, been a few months now playing around, and have learned a lot...wood cuts perfect, acuracy on the 0.1mm 0.2mm range...wirh aluminium differwnt story, having a lot of issues..it cuts, but i cannot hae a consistent result...it has a terrible backlash and also wobling on the z axis, the column moves a lot. It seems to be that the spindel arm i too long, im thinkimg on putting some kind of support, like a triangled shaped support...any comments on you guys? thx! if you need more info let me know
    This is what I did, cut on the machine.
  4. #24
    Jun 2019
    Any updates with this machine? I'm looking to get a 6040 size. How was the setup? Was it a difficult setup?
  5. #25
    Dec 2019
    27
    Quote Originally Posted by DenizY View Post
    for me it was the first time with a CNC machine, therefore it was quite challenging, but at the end the main problem was to make the parallel port work with my old dell laptop. I disabled all the services and auto runs and after that was working well. the configuration of the B axis was missing in the instructions, but this is easy, it is the same as A.
    next to the parallel port there is a small connector you can use for the Z probe. The hand wheel will behave strange if your computer is not connected, it will turn the B axis together with other axis, probably because it is done for 4 axis max. The trunion table works but as somebody wrote here is weak, not only because of the drivers, but also because there is no harmonic reduction. you can use it to mill soft materials thou. I bought a rotary axis with harmonic reducer and it works good. I am using Fusion and I have the 3040 version.
  6. #26
    Dec 2019
    27
    I forgot: the water tank is the weakest thing in this machine: it was leaking from the very beginning. I replaced it with an aluminium one:
    last, but not least, the spindle is not connected to the board, therefore you need to start and stop it manually and you have to set up the speed also manually. I wonder if anybody succeeded connecting it to the board, but probably I will make the upgrade when I will change the board, I am thinking about NVUM with the hadwheel. And DM542.
  7. #27
    Dec 2019
    27
    Table 2 for rotary axis
Page 2 of 2 12
  1. Router Design - Comments please
    By Winter in forum DIY CNC Router Table Machines
    Last Post: 05-23-2012, 03:27 PM
  2. About to start my first CNC router - would love comments
    By GPT in forum CNC Wood Router Project Log
    Last Post: 07-11-2011, 05:31 AM
  3. Proposed router design. comments please
    By pavlo in forum DIY CNC Router Table Machines
    Last Post: 02-26-2010, 06:18 AM
