586,115 active members*
3,494 visitors online*
IndustryArena Forum > CNC Electronics > Xylotex > Which is Better 269oz or 425oz motors?
    Dec 2005
    238
    I will shortly start building a Solsylva router and am looking at purchasing one of the Xylotex motor kits to power it. The price difference between the 269oz and 425oz motors is minimal so I need to decide which motors I will buy. I have seen on this site a mention that using motors too big for the job is bad for the motors but this claim I have been unable to find anywhere else on the internet. I believe that the maximum usable speed of the 425oz motor is lower than the 269oz but I could overcome this problem with larger leadscrew if rpm is not too low.
    Has anyone used the 425 oz motors on the Solsylva router and what speed has been achieved?
    What usable rpm could I expect from a 269oz motor?
    What usable rpm could I expect from a 425oz motor?
    What is your opinion?
    1695
    The best way to decide is to look at the torque vs rpm curve for the motors. To put it simply, the one with the higher torq X rpm number is the better one.
    Dec 2005
    238
    Quote Originally Posted by H500 View Post
    Thank you for your reply
    Unfortunately Xylotex advise they have no such curves for these motors. I will see what I can dig up.
    cheers
    Jun 2005
    866
    Check Keling, I believe their motors are the exact same ones that Xylotex sells but a different name:
    http://www.kelinginc.net/SMotorstock.html
    They have torque curves. The 425oz-in motors drop torque fast.
  1. dc motors use?
    By jammer53 in forum Stepper Motors / Drives
    Last Post: 12-25-2006, 02:23 AM
  2. 425oz or 269oz ?
    By gun_maker in forum DIY CNC Router Table Machines
    Last Post: 07-06-2006, 02:52 AM
  3. Which motors do I need?
    By Juancar in forum CNC Wire Foam Cutter Machines
    Last Post: 11-07-2005, 07:40 PM
  4. Are these motors any use?
    By seware74 in forum MetalWork Discussion
    Last Post: 05-05-2005, 11:44 AM
  5. How big of motors do I need
    By CNC Brute in forum DIY CNC Router Table Machines
    Last Post: 12-06-2003, 04:23 PM
