586,105 active members*
3,246 visitors online*
IndustryArena Forum > CAM Software > BobCad-Cam > Setting direction for "Planar"? v.26
    Aug 2010
    43
    I just can't find a way to do it.I'm doing a roundover on two edgese. The tool starts at the top for the right edge, but at the bottom for the left. I suppose if I chose "Conventional Mill" for the left it would reverse and start at the top, but then I'd be cutting the wrong way. Maybe because I've chosen "Zig and Zag" it doesn't matter? Is that why the choice isn't offered?
    Apr 2009
    3376
    Re: Setting direction for "Planar"? v.26
    Contours with a profile strategy ??
    Aug 2010
    43
    I am choosing a surface for geometry, so I don't see setting a contour as relevant. The toolpath works fine though, even though the start point is reversed for the left and right portions.
    May 2013
    701
    Quote Originally Posted by robobass View Post
    Maybe try this It looks like this may work for you
    In V26 we have the copy paste for the Feature I picked half and set the Lace Angle at 0 in the first feature and then picked the other half in the second copied feature with Lace Angle at 180
    Both Feature are in Zig Zag
    The second pic. I set the 1st feature at Zig, 180 Lace and Conv cut
    2nd feature at Zig, 0 Lace and Conv cut
    Looks like this gives a climb cut in both side starting at tops
    Hope this may help
    RAF
    Apr 2009
    3376
    Threw me off,thought you were speaking as in a round over tool
  1. an odd problem... mill "lurches" when changing direction.
    By SSN Vet in forum Benchtop Machines
    Last Post: 04-01-2016, 08:34 PM
  2. Replies: 5
    Last Post: 01-12-2014, 07:07 PM
  3. X Axis "Goes Off Pattern", "Awry", "Skewed", "Travels"
    By DaDaDaddio in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 05-06-2013, 09:59 AM
  4. Motor "pulsing" but not stepping continuously in same direction
    By cnczo2629 in forum CNC Machine Related Electronics
    Last Post: 06-06-2011, 11:36 PM
  5. Replies: 7
    Last Post: 05-07-2009, 08:02 PM
