586,106 active members*
3,330 visitors online*
IndustryArena Forum > MetalWorking Machines > Kitamura > Kitamura Mycenter H400 - tool clamp issue
    Dec 2009
    539
    Hello all
    hoping someone with a Mycenter H400 or similar can help out. I am having the strangest issue. When I go to do a tool change -, the door opens, the arm rotates 90° to grab the tool out of the spindle - its perfetly aligned in the groove - but then it moves forward before the tool is unclamped and contineues the cycle. However the unclamp cylinder is all the way forward and hitting the unclamp dog - but its just not letting go of the tool immediately. So the arm continues with the tool change cycle - but the tool is still clamped in the spindle. An instant later - the tool unclamps and slides out and drops out of the spindle. Now here is the weird part- this only happens on a tool change if you wait more than 10 minutes between changes. So after it drops a tool - it works perfectly. Of if you manually do a clamp/unclamp and then do a tool change its fine.
    I have rebuilt the clamp cylinder, the drawbar, the hydraulic pump - nothing is helping.
    If someone has this machine - can you tell me that when you do an unclamp - does the pressure drop from the standard 4.9mPa to about 1 then back up to 4.9 (thats what mine does - not sure if its normal). I am indesperate need of this machine and I cannot get it to work.
    Thanks - John
    Mar 2018
    45
    Re: Kitamura Mycenter H400 - tool clamp issue
    Please check your m06 macro program first.
    Check arm proxy sw input when tool change by arm.
    For more detail mail me on [email protected].
    I have kitamura h500 machine.
  1. Kitamura Mycenter H400
    By Dave Reid in forum Kitamura
    Last Post: 12-23-2011, 10:00 PM
  2. Kitamura 1997 H400 pallet door problem.
    By Robvcnc in forum Kitamura
    Last Post: 09-09-2011, 11:48 PM
  3. Kitamura Mycenter 2 Tool Change Macro Program
    By pcreek in forum Kitamura
    Last Post: 05-18-2011, 12:23 PM
  4. Replies: 5
    Last Post: 08-09-2007, 09:25 PM
  5. Replies: 2
    Last Post: 05-25-2006, 05:15 AM
