586,047 active members*
3,693 visitors online*
IndustryArena Forum > Tools / Tooling Technology > Calibration / Measurement > Looking for Edge Finder with 1/4" Shank
Results 1 to 12 of 12
    May 2013
    23
    Almost all of the edge finders I've seen have either a 1/2" or 3/8" shank. I use a Bosch Colt Router so the maximum shank is 1/4". Does anyone know of any edge finders with a 1/4" shank?
    Aug 2009
    119
    Re: Looking for Edge Finder with 1/4" Shank
    Fisher Machine makes a 1/4" shank edge finder, just look on eBay.
    MICRO EDGE FINDER BY FISHER 1/4 or 3/8 or 1/2 SHANK | eBay
    But the max speed they recommend is 1500 rpm, will your router go that slow?
    May 2013
    23
    Thanks for looking but I saw that one and no I can't go that slow. So the hunt continues...
    Apr 2004
    5737
    You don't need to turn the router on when you're finding edges. Just feel the edge where it is offset; you can actually feel smaller differences than you can see.
    Andrew Werby
    Website
    Aug 2009
    119
    Andrew, have you ever done a test to verify how accurate that is? Compare it to a reading with a spinning spindle using a mill
    I'm wondering whether it wouldn't work to spin the router by hand, or rig up a way to spin it with a dremel or something. I have the same need...
    May 2013
    23
    Good point about not having the router turned on. Might be worth a shot to try it. It just seems a bit odd to me that there really aren't any 1/4" shank solutions.
    Dec 2009
    166
    Hi guys just a question ? are you using Mach3 if so why bother with a edge finder when you can use a a probe
    May 2013
    23
    Yes, I'm using Mach3 but when I inquired about this in another thread people said to use an edge finder. I actually have a couple of probes but never go around to "programming" Mach 3 for the touch routine.
    Dec 2009
    166
    Well a probe is the only way to go I have built a complete set of routines. All that you will ever need and I can help you through any issues.
    that you might have
    Look for Squirrel Probes in this site I just posted a new download link yesterday these work with Mach3 using a standard screen set .
    Dec 2009
    166
    Just another note I never use a probe in the spindle chuck I always use it offset this eliminates any discrepancy in the probe ball and does not require the probe to spin true .
    May 2013
    23
    I went to that thread to check out your routine but it says that the download link is broken.
    Dec 2009
    166
    https://dl.orangedox.com/nVdNa3IFiTCchbpdIu
    this is the link in my last post i just tested it
    it's working.
    Let me know if it does not work
  1. MACH3, How to Make " Edge Finder "
    By Robiz in forum Machines running Mach Software
    Last Post: 07-22-2020, 01:20 AM
  2. 1/8" (0.125) Automatic Edge Finder/Setter
    By xcayba in forum Calibration / Measurement
    Last Post: 02-12-2012, 07:14 PM
  3. edge finder
    By bbrown2005 in forum Calibration / Measurement
    Last Post: 02-13-2009, 02:18 AM
  4. Edge finder
    By eggo in forum Australia, New Zealand Club House
    Last Post: 08-04-2008, 04:57 PM
  5. Has anyone used this edge finder?
    By l u k e in forum MetalWork Discussion
    Last Post: 03-19-2008, 07:52 PM
