First power up normally and if the power is on the servo's, try turning the shaft of the motor, if it resists you, then the controller has command of the servo and means CNC is inputing a ±10vdc signal to the drive.
If you can turn the shaft, then measure the ±10vdc signal which should vary when you turn the motor shaft, this means the CNC is trying to command the drive but it is not responding.
Make sure the drive enable is on.
To trouble shoot the drive without the CNC controller, you can remove the ±10v signal and feed it with a 1.5~12v battery box.
Also to check the drive if all are the same size, temporarily swop two of the drives over.
Al.
Albert E.
