Originally Posted by
cce1911
I've got a project involving pistol targets made from AR500 steel. I'm under the impression that cutting the shapes with CNC waterjet is a better option than cutting with plasma because of a minimal heat affected zone. I've been told that plasma, while not as bad as oxy/acetylene, will still temper the edge of the plate leading to cracking. Can anyone comment on the pros and cons of cutting 3/8" AR500 with waterjet vs plasma?
Also, I need som .375" dia holes in the plates. Can they be cut with wj or plasma or will they need to be drilled? Tolerances are not extremely critical on these parts.
