Hi guys
So this is my second post. It seems like every time a make a little progress a new problem arises. I presume many of you have had the same pains.
Now that my problems with my motors being unreliable and making some strange screeching sounds intermittently after restarting my machine are have been for the most part taken care of
Iv'e developed some major noise problem
My machine runs with a lead shine MX4660 and Mach3. I have 4 425oz 3/8 shaft motors. I've cheaped out and bought 5 limit switches from china and also a 2.2kw spindle with a HY inverter. Thing were working really well with the machine until I fired up the spindle. I've noticed that my limit switches trigger randomly and my motors make some extra little jogs when I stop moving in one direction. All my wires are shielded and i've moved the vfd as far away as I could from the machine. I initially had the spindle power cable running in the cable drag chain but took that out too remove the proximity to other wires. None of these attempts have changed anything.
So my question to the group is the following
1- Should I invest in high quality switches like the the Pepper+fuchs or is that unlikely to solve my issues given that the RF is still present
2- Where is the RF noise being received for my motors? Is it at the the level of the Leadshine drivers or is it closer to where the motors are? I presume that the black connectors from the motors connecting to the orange shielded wires purchased from cncrp are shielded as well or could they be acting like antennas if they're not?
3- Where is the RF most likely coming from? I've read that VFDs are probably the most common source of significant VF but moving it behind and enclosed cement wall did not change anything. My suspicion is that most of the RF is coming from the spindle itself.
4- So far thing i've read to take care of the problem include the following:
-Keep the VFD wire going to the spindle short
- don't run the wire going to the spindle close to limit switches and motor wires
- read about capacitors placed at the drivers input for each coupled limit switches (x+/x- y+/y- A-) as a way to take care of noise issue for limit switches
I was hoping to get going with my machine but because of the limit switches triggering and the motors taking additional micro steps when stopping movement in one direction my system is unreliable for now
HELP!
Antoine
