586,113 active members*
3,338 visitors online*
Results 1 to 6 of 6
    May 2016
    108
    BF25 cnc mill conversion
    Hello, my name is stef i am 24 years old and come from Holland.
    2 years a go i bought me self a bf25 mill, i used it for almost one year, afther that i had to opportunity to buy a BF45 mill.
    After having installed the new mill the bf25 had no use anymore. I decided to convert that one to cnc.
    finished the conversion about 4 months ago. Made some very nice work pieces on it. But the mill was starting to get a little bit to small.
    The y axis had only 175mm of travel. This weekend i started to add more space to the y axis with a column spacer and a head spacer.
    The column spacer i already in place and the head spacer is also finished but not yet placed. This mod give me a travel of 250mm on the y axis.
    I already put a 3 phase 1.1 kW motor on top with a 2:1 reduction witch gives me a spindle rpm of 6000.
    The head spacer will give me also the opportunity to place the milling motor more to the back. This wil give me enough space to place a big air cilinder above the spindle for making a ATC on it.
    The ATC is a big thing on my wish list. Probably will add a 12 of 16 places loader on it.
    Machine specs:
    X and Y nema 24 3NM closed loop motors
    Z axis nema 34 8NM closed loop motor
    Spindle motor 1.1kw 3 phase motor
    electronics: usbcnc v5b
    Mist coolant
    now time for some pictures!
    stef
    May 2016
    108
    Re: BF25 cnc mill conversion
    Here are some pictures of parts i have made so fare:
    way more to come!
    stef
    May 2016
    108
    Today I installed the headspacer. It looks great! Yesterday i bought a air cilinder the same as on the tormach so i can start working on the ATC.
    stef
    Aug 2010
    630
    How long did you make the column extension ?
    Inner Vision Development Corp. - http://www.ivdc.com
    Website Design & Development. Shopping Carts, SEO and more!
    Nov 2009
    4415
    Very nice build and parts you have made.
    A lazy man does it twice.
    May 2016
    108
    I extend the column with 88mm.
    The head spacer is 65mm thick.
    stef
  1. Drillbit test with mill LMS 3960 mill conversion
    By msimpson99 in forum Benchtop Machines
    Last Post: 10-20-2013, 11:20 AM
  2. New Mill Conversion
    By electromech31 in forum Knee Vertical Mills
    Last Post: 12-20-2012, 06:08 PM
  3. Replies: 18
    Last Post: 01-31-2012, 02:55 PM
  4. Mill alone is enough to do a CNC conversion of itself?
    By yang_cnc in forum Benchtop Machines
    Last Post: 06-27-2009, 05:21 AM
  5. mill conversion
    By frankg521 in forum Mechanical Calculations/Engineering Design
    Last Post: 06-29-2007, 03:34 AM
