586,036 active members*
3,715 visitors online*
IndustryArena Forum > MetalWorking Machines > Tormach Personal CNC Mill > Help wiring Tool Height/ Z axis height base into C10 BOB
    Mar 2014
    I have been unsuccessful trying to get me tool height pad wired to my C10 BOB. Has anyone done this successfully? I have tried configuring Mach 3 using this diagram, but was unsuccessful.
    I have tried using the Pull up/down resistors on the BOB and even tried adding a 1k inline without luck.
    What I will note is the fact that I was able to get the Digitize box in Mach 3 Diagnostics to go on/turn green when I touched the alligator clip (that is supposed to be clipped to the bit) to a metal surface of the machine.
    Thanks in advance for lending a hand!
    Mar 2007
    2083
    Re: Help wiring Tool Height/ Z axis height base into C10 BOB
    a diagram of how you have connected any limit switches and the tool height pad will help
    its missing from your post
    I expect you need a pull up resistor so the input is high until the tool grounds it
    8is the input set to active low ?
    with the C10 breakout board ,
    one jumper selects all pull up or all pull down resistors for all 5 inputs
    John
    Jul 2004
    1424
    I recommend you ask this question in the Benchtop machines forum.
    The machines those of us here own don't have "C10 BOB".
    http://www.cnczone.com/forums/benchtop-machines/
    Tim
    Tormach 1100-3, Grizzly G0709 lathe, Clausing 8520 mill, SolidWorks, HSMWorks.
  1. Replies: 2
    Last Post: 03-02-2017, 01:54 PM
  2. PCB height probing - wiring
    By AlexP. in forum PCB milling
    Last Post: 06-29-2014, 07:17 PM
  3. What should be the height of Router base?
    By woodworksfla in forum CNC Wood Router Project Log
    Last Post: 10-09-2012, 01:06 PM
  4. Setting the Z axis tool change height
    By TR MFG in forum Fadal
    Last Post: 11-07-2009, 04:22 AM
  5. Setting up Z axis tool holder height above table
    By EL34 in forum DIY CNC Router Table Machines
    Last Post: 07-27-2007, 09:28 PM
