586,116 active members*
3,474 visitors online*
IndustryArena Forum > CAM Software > BobCad-Cam > Thread milling multiple holes
Results 1 to 7 of 7
    Jun 2010
    I'm using Bobcad V23 and I'm trying to use a single point thread milling tool. I want to thread multiple 8-32 holes but can't find any way to select more than one. It will make the path for one hole fine but I have 24 holes that need to be threaded. It seems odd that you can only select one hole instead of all of them.
    Does anyone know how this can be done or is it maybe a limitation on V23?
    Thanks.
    Dec 2011
    361
    Re: Thread milling multiple holes
    Leharker,
    In BobCAD-CAM V23, threadmilling is only supported one hole at a time. If you were to upgrade to the newer version, you would be able to find support for threadmilling multiple holes in one operation.
    Apr 2009
    3376
    single point thread mill 8-32 ?????????
    That is interesting
    May I ask why ?
    Jun 2010
    I'm assuming that you're asking why do this with a small size thread rather than just using a a tap. I have three plates to mill that will each have 24 - #8-32 threaded holes to make and I had just recently learned of the possibility of using a thread mill. In retrospect, I think it will be just as easy to put a hand tap in a hand drill to do the threading. Our mill doesn't have the tight control to make using a spiral tap possible.
    Thanks for the answer from SeanDa. I had assumed this might be the case but just checking with those more experienced.
    Apr 2009
    3376
    Definitely tap inmo
    You can make a guide out of some 1018 rectangular stock (say,,2x2x1/2thick)
    That way you can use a spiral point tap (assuming your plate is not too thick vs. length of tap)
    Then you can go to town with hand drill confident that you are pepindicular
    I never heard or seen a single point thread that small,,,maybe???,,,if there is,,it will cost
    Thread milling is cool,,but it is not very fast or efficient for smaller sizes
    For odd size pitches and larger diameters,,,it shines
    Jul 2009
    219
    Oh threadmills can go pretty small,
    2-56 Carbide Thread Mill Uncoated
    As an example.
    I disagree about the speed or efficiency vs a tap, when you can create a thread gage perfect hole with a single helix that you can adjust via radius comp. Also if (When?) you break the tool in the hole, the cutter can be easily removed.
    To each his own, I prefer thread-milling any day to tapping but me and tapping seem to have a tough relationship!
    May 2010
    62
    Might want to create a subroutine, if your control supports it. Go to location, run sub that thread mills, rapid to new location, repeat......
  1. Matsurra Pecking multiple holes
    By Swimminginblues in forum G-Code Programing
    Last Post: 09-10-2012, 07:44 PM
  2. Cutting multiple holes on a single part
    By CNC-Dude in forum Torchmate
    Last Post: 02-06-2012, 12:11 AM
  3. Multiple tapped holes on NC, tapping fluid, or is coolant ok?
    By Brian FRF in forum MetalWork Discussion
    Last Post: 12-30-2009, 12:21 AM
  4. Drill Multiple Holes - Newbie Question
    By NetStorm in forum BobCad-Cam
    Last Post: 06-20-2007, 01:59 PM
  5. Thread milling with single or multiple inserts?
    By magneto259 in forum MetalWork Discussion
    Last Post: 04-12-2007, 04:39 PM
